lotus_65 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region ![]() |
My throttle cable broke at the carb linkage so it needed to be replaced. No big deal, right?
Unfortunately the white plastic sleeve is broken at the firewall and WILL NOT BUDGE. Won't pull, won't push. I can (barely) get a needle nose on it, but it seems bound up inside the tube somewhere. I haven't pulled the cable out of the sleeve yet, as I had hoped to attach a string to help the new cable into place. I also dis-assembled the interior to get at the tunnel from the shifter, but there's no obvious advantage there. I ALMOST bought a sawzall to cut another access panel there, but came off that ledge... for now. What a PITA. (IMG:style_emoticons/default/headbang.gif) Anyone? paul |
lotus_65 |
Lo-Fi Version | Time is now: 25th June 2024 - 11:13 PM |
