computers4kids |
Love these little cars! ![]() ![]() ![]() ![]() Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None ![]() |
I picked up a 9 230 081 050 new Bosch distributor for $50 at the GAF swap meet today and just looking for some tuning tips. I am used to tuning FI motors with a vacum advance. I will most likely drop in a pertronix unit as well so not to mess with points.
What do I need to know about using this guy with a cabureted motor? Since this is a fully centrifigual distributor, what is the proper timing specs for a 1.8 with weber 40s? Do I set the timing at 3200 rpm for about 27 degrees and not worry about where the timing ends-up at a idle? Appreciate any tips, Mark |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
also... unless that 050 is NEW, the bushings could be kinda worn, and when you watch the timing with a light, it will move around several degrees...... hardly a precision piece these days. Mallory has bearings and very stable spark timing.
Motor On, AA |
Lo-Fi Version | Time is now: 28th June 2024 - 11:06 PM |
