Where do i find those Euro front turn signal kits ?, also can somone tell me about where to get some sways? |
mikeyboy_85 |
Sep 9 2007, 07:37 AM
Member Group: Members Posts: 82 Joined: 24-May 07 From: australia Member No.: 7,758 |
Hey, i have an imported 914 and wanted to get the euro signals for the front to make the parker seperate from the turn signal.. and also the car handles not to bad but i think it could benifit from sway bars, could someone please tell me what brand to get etc and is installation hard?
Rick_Eberle |
Sep 9 2007, 03:57 PM
Member Group: Members Posts: 390 Joined: 14-January 04 From: Geelong, Australia Member No.: 1,558 |
I converted the indicators myself. Just cut an aluminium plate to fit the indentations in the light housing, and drill a hole in the bottom to fit the light from the side marker. That will work as your parking light.
Where in Australia are you? I'm in Geelong. |
914-8 |
Sep 9 2007, 07:07 PM
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
I converted the indicators myself. Just cut an aluminium plate to fit the indentations in the light housing, and drill a hole in the bottom to fit the light from the side marker. That will work as your parking light. Where in Australia are you? I'm in Geelong. Do you have any pics of your conversion? Not quite sure what you mean about "fitting the light from the side marker." The side marker light seems to be a part of the round plastic side marker assembly that can't easily be removed. Thanks! |
Rick_Eberle |
Sep 11 2007, 10:41 PM
Do you have any pics of your conversion? Not quite sure what you mean about "fitting the light from the side marker." The side marker light seems to be a part of the round plastic side marker assembly that can't easily be removed. Thanks! Actually, when I really think about it, it was only the wiring that got used... I switched to H4 headlights, and they had an optional parking light socket, and I put that into the bottom of the indicator housing. |
Lo-Fi Version | Time is now: 29th June 2024 - 12:24 AM |
