alpha434 |
My member number is no coincidence. ![]() ![]() ![]() ![]() Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains ![]() |
Alright. How do I make it?
I have a source for the ferro-fluid. I just don't know how to get it to bond into a paint. And I'm sure someone here knows. I'll just bet Clayton shows up here and says he's got a 55 gallon drum in his basement. (IMG:style_emoticons/default/KMA.gif) |
alpha434 |
Ferrofluid is a liquid that has both magnetic tendencies and is electrically conductive. It is the primary component to the paint that the military currently uses for the stealths.
I just don't know how to make it bond properly, or if it would function properly as a mixture with "normal" paint. Brian. Your's sounds like the older "iron ball" paint. Which would work just fine. What kind of finish does it leave? |
Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
Ferrofluid is a liquid that has both magnetic tendencies and is electrically conductive. It is the primary component to the paint that the military currently uses for the stealths. I just don't know how to make it bond properly, or if it would function properly as a mixture with "normal" paint. Brian. Your's sounds like the older "iron ball" paint. Which would work just fine. What kind of finish does it leave? Ferro fluid is very fine iron particles in an oil suspension. You will find it is often used in high power speakers. I work with engraving machines. Ferro fluid is used as a dampening component. I am interested in what you have found. I would like to acquire some myself. |
Lo-Fi Version | Time is now: 29th June 2024 - 12:28 AM |
