Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
I have '75 1.8 that the PO installed a nice center console complete with gauges. The volt meter works, clock didn't until I pulled it out and found the ground wire disconnnected. Now it keeps perfect time.
There is a plate currently where the oil temp sending unit goes. I also have a oil temp sending unit. I believe the order of installation is the red o-ring, the sending unit itself, the gasket and then black cover. I'm assuming I ground the black cover and the lead from the gauge goes to the sending unit. I can't seem to locate that wire. I'm assuming that the oil temp lead goes thru the center tunnel into the engine compartment. Where should I look? Will a ground wire also be with it? What color should the wires be? Brown=ground? ![]() ![]() |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
might not be ideal to route the wire through the hole for the shift rod but other than that, looks good!
(IMG:style_emoticons/default/smilie_pokal.gif) Andy |
Cevan |
might not be ideal to route the wire through the hole for the shift rod but other than that, looks good! (IMG:style_emoticons/default/smilie_pokal.gif) Andy I'm dropping the motor this winter in order to clean up the engine bay and treat some rust issues, so I figured I'd just run the wire through there for now. I have it zip-tied so it can't make contact with the shift rod or abrade against the engine mount. |
Lo-Fi Version | Time is now: 26th June 2024 - 12:36 AM |
