BMXerror |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 ![]() |
Well, with all the work that I'm doing to my car lately, I might as well start my own progress thread.
Backstory I bought 4702912742 from my pops about a year and a half ago for $600 dollars, but it wasn't a steal. It had been sitting for about five years and needed a lot of work. He A couple years later he had been looking for a teener for a little while and picked this one up cheap at a dealership in Pomona Ca. He drove it for a while, but it had tons of problems, and soon he decided to sell it. However, the person who test drove it blew first gear, and out to the back yard it was sent. Fast forward five years to when I was financially ready to get a car to start racing. Long story short, after deciding that I wanted the 914 instead of an older Miata, I told him I was interested. He said that if I bought him a set of mufflers for his bike, we'd call it even. After that I spent about another 4K just getting it drivable. I replace all four rotors, rebuilt all four calipers, replace the brake lines with braided steel, replaced the hard lines that I broke, replaced the master cylinder, resealed the motor (after my socket and extension locked the motor up), bought two trannies for it (the first one was no good), put a new clutch and pilot bearing in it, put new rubber on the ground (Khumos), fixed and lubed all kinds of latches and hinges to be able to get into all the various compartments, replaced most of the vacuum lines and fuel lines.... the list goes on. These were all just stock replacements to get it running well. I further had to fight with the injection system for a few months until I figured out that I had it hooked up wrong. (IMG:style_emoticons/default/headbang.gif) Of course, this is the very abbreviated version of the story. As anyone with one of these things knows, the words it takes to describe what parts you changed don't even come close to showing the blood, sweat, and yes, sometimes tears that you put into your work. But anyways, it is running decent now (the motor is still a little tired) so it's time to do some improvements. After all, racing is what I bought the thing for. So I'll try to bring anyone who cares up to date on some of the things I've been working on. Mark D. |
BMXerror |
A couple months ago, I had an electrical short under the dash that took forever to find. I thought it was the ignition switch (which has had problems), but I was wrong. I ended up taking my vacation from work to fix it, as it was the only car I had at the time. I ripped the whole dash out and found my electrical problems. It turned out there was more than one. Anyways, the stock dash was thrashed when I bought the car, and it looked even worse by the time I got it out of the car. Since I got the electrical fixed way earlier than I expected to, I decided this was a good time to do my stripped out dashboard.
All I did is take the steel frame, cut it down to a flimsy framework, and then wrap some aluminum around it. Unfortunately, I don't have a 53" sheet metal break, so all the bends are hand bent around random pieces of angle-iron and 2X4. The long bends on the top and bottom had to be relief cut to facilitate this. The look isn't as good as I'd like, but it's alright. ![]() Mark D. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:04 PM |
