Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
I have '75 1.8 that the PO installed a nice center console complete with gauges. The volt meter works, clock didn't until I pulled it out and found the ground wire disconnnected. Now it keeps perfect time.
There is a plate currently where the oil temp sending unit goes. I also have a oil temp sending unit. I believe the order of installation is the red o-ring, the sending unit itself, the gasket and then black cover. I'm assuming I ground the black cover and the lead from the gauge goes to the sending unit. I can't seem to locate that wire. I'm assuming that the oil temp lead goes thru the center tunnel into the engine compartment. Where should I look? Will a ground wire also be with it? What color should the wires be? Brown=ground? ![]() ![]() |
Grelber |
Insert favorite Don Rickles joke here. ![]() ![]() ![]() Group: Members Posts: 690 Joined: 30-May 06 From: McKinney, Texas Member No.: 6,107 Region Association: Southwest Region ![]() |
That's about right. Mine runs between the "T" and the "E", even on hot days here in Texas. If you search, I seem to remember a thread where someone had done a conversion that had shown the actual temps for each letter on that gauge.
Lo-Fi Version | Time is now: 26th June 2024 - 01:26 AM |
