CB Performance Air/Fuel meter?, Who's used it, and with what kind of results?? |
jaybird840 |
Sep 20 2007, 04:39 PM
Member Group: Members Posts: 163 Joined: 27-September 06 From: Austin, TX Member No.: 6,927 Region Association: Southwest Region |
Hey Gang,
I've been eyeballing the CB Performance Air/Fuel meter to assist in dialing my carbs in. My eye is not well-trained enough to do it by looking at the spark plugs, so I though an A/F gauge might do the trick. It's about $130 for a three-wire heated O2 sensor, gauge, and exhaust bung. Anybody used it? Any others I should be looking at? I'd consider the Innovate unit, but it's over $300, and until I megasquirt, I don't think logging data will be that useful for my street only car. Also, as the car has dual carbs, would it be a good idea to weld in two bungs(or even four) so that I could switch between cylinder banks, or even individual cylinders? My thought is to mount the gauge in my existing clock (non-working) hole in the console. Any advice related to A/F meters and carbs is welcomed... Thanks!! --Jaybird |
PeeGreen 914 |
Sep 20 2007, 05:18 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
If you need something to get you carbs dialed in correctly you should get one of these...
http://www.automotion.com/productpage.aspx...amp;name=Unisyn |
Lo-Fi Version | Time is now: 6th January 2025 - 03:16 PM |
