CB Performance Air/Fuel meter?, Who's used it, and with what kind of results?? |
jaybird840 |
Sep 20 2007, 04:39 PM
Member Group: Members Posts: 163 Joined: 27-September 06 From: Austin, TX Member No.: 6,927 Region Association: Southwest Region |
Hey Gang,
I've been eyeballing the CB Performance Air/Fuel meter to assist in dialing my carbs in. My eye is not well-trained enough to do it by looking at the spark plugs, so I though an A/F gauge might do the trick. It's about $130 for a three-wire heated O2 sensor, gauge, and exhaust bung. Anybody used it? Any others I should be looking at? I'd consider the Innovate unit, but it's over $300, and until I megasquirt, I don't think logging data will be that useful for my street only car. Also, as the car has dual carbs, would it be a good idea to weld in two bungs(or even four) so that I could switch between cylinder banks, or even individual cylinders? My thought is to mount the gauge in my existing clock (non-working) hole in the console. Any advice related to A/F meters and carbs is welcomed... Thanks!! --Jaybird |
Joe Ricard |
Sep 20 2007, 09:54 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
1st off I have a CB narrow band in my tool box. It works to get you in the ball park. it will tell you rich from lean. that's about it.
I now have a wide band and am able to jet down to half sizes and make great power great milage and throttle response. I can see a difference in the reading between hot humid days and cold dry days. each requiring different jets. I got lots of jets. |
tommy914 |
Sep 20 2007, 11:10 PM
Life is a journey, enjoy every turn. Group: Members Posts: 1,103 Joined: 15-September 03 From: Ridgeland, MS Member No.: 1,165 Region Association: None |
1st off I have a CB narrow band in my tool box. It works to get you in the ball park. it will tell you rich from lean. that's about it. I now have a wide band and am able to jet down to half sizes and make great power great milage and throttle response. I can see a difference in the reading between hot humid days and cold dry days. each requiring different jets. I got lots of jets. Joe, What wide band unit did you go with? |
Lo-Fi Version | Time is now: 6th January 2025 - 03:16 PM |
