neo914-6 |
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 ![]() |
Just got a Dell Inspiron 530S with Duo Core processor.
Spoke to Dell Tech Support and they say I can transfer XP files from my old computer to Vista with a wireless router. What should I shop for, there's alot of routers? Are they priced for speed limits and what should I get at a minimum? Can you do it with a cable? I also have files from a PC with Win98 that I'd like to transfer. I'm told this isn't possible to Vista with a router. I've burned some CD's but it's a really slow process. It won't recognise my thumb drive. They say I should also get a external hard drive to store files and keep less on the computer (better performance) and to avoid losing data in a crash or corruption. I have a 220GB internal drive, how much should I keep "free"? Page loading seem slow, I expected much faster speed. I currently have 2GB and can expand another 1GB so Dell TS sold me a 512MB memory upgrade. Is page loading limited by ISP or memory? My ISP (SBC) has a faster DSL upgrade. |
Gustl |
914 enthusiast & historian ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,539 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria ![]() ![]() |
for the file transfer - why don't you take a cross-over cable?
you could configer a peer-to-peer network within 30 sec and a TCP/IP network protocoll is available on every Windows OS since Win95 just set up a file share - that takes you 10 sec - and than copy the files with 100 Mbit/s that seems to be the cheapest and easiest way ... (IMG:style_emoticons/default/bye1.gif) Gustl |
cooltimes |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,508 Joined: 18-May 04 Member No.: 2,081 Region Association: None ![]() |
I hope this falls within the rhealm of Felix's questions. If not, I apologize for taking the thread out of his focus on doing his new system.
What is a cross over cable? Can you explain the process you mentioned here? Sure would be a BIG help to some dummies like me since I am in the process of putting my 500GB USB files on DVD and each DVD (4.3GB) is taking wellover an hour using Nero. My purpose is to format the USB HD so it isn't running both Windows and UNIX (Ubuntu). Is formatting is the only way I can remove a dual system since Unix doesn't appear to have a process I understand clearly to remove one and not the other system. Thanks. Cooltimes for the file transfer - why don't you take a cross-over cable? you could configer a peer-to-peer network within 30 sec and a TCP/IP network protocoll is available on every Windows OS since Win95 just set up a file share - that takes you 10 sec - and than copy the files with 100 Mbit/s that seems to be the cheapest and easiest way ... (IMG:style_emoticons/default/bye1.gif) Gustl |
Gustl |
Can you explain the process you mentioned here? hmmm ... that's a little difficult to describe for me it's a standard network cable Cat5 <=> Cat5 with some crossed connections this cable allows to connect 2 computers without hub/switch so you only have to pay about US$ 5.00 for a 7 feet cable that allows full network connectivity the setup is pretty easy: choose a IP range like 192.168.0.1 & 192.168.0.2 with 255.255.255.0 as subnet mask (all to be done at your IP settings) then set the file share on one computer search the network from the other computer (via IP) and connect to the share then you have full network function a better description may come from a nativ speaker ... (IMG:style_emoticons/default/bye1.gif) Gustl |
cooltimes |
Can you explain the process you mentioned here? hmmm ... that's a little difficult to describe for me it's a standard network cable Cat5 <=> Cat5 with some crossed connections this cable allows to connect 2 computers without hub/switch so you only have to pay about US$ 5.00 for a 7 feet cable that allows full network connectivity the setup is pretty easy: choose a IP range like 192.168.0.1 & 192.168.0.2 with 255.255.255.0 as subnet mask (all to be done at your IP settings) then set the file share on one computer search the network from the other computer (via IP) and connect to the share then you have full network function a better description may come from a nativ speaker ... (IMG:style_emoticons/default/bye1.gif) Gustl Thanks. You made what I wanted to know clear and using your help along with Pnambic's later on post, I am going to do me a private home network. I already have a router and the Cat5 cable so curious as I am, I gotta try this with an old laptop my son gave me that has been in the closet for the last 3 years. 914's are super but the users here make it even better. Over and out. Thanks |
Lo-Fi Version | Time is now: 27th June 2024 - 06:53 PM |
