Engine knock/tapping noise, can't figure it out |
Hammy |
Sep 26 2007, 08:19 PM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
My carbed 1.7 has a tap tap tap/knock knock knock noise at idle. It seems to disappear with engine speed but I can't tell if it's just the exhaust noise covering it up. I adjusted the valves using the Capn's procedure and set them all at 1 full turn past contact, engine has hydraulic lifters. Still the same knock/tap noise....
What is it? Is it fatal? This engine has been good to me and I just need it to last a little while longer until I get myself a FI engine hopefully soon... |
Hammy |
Sep 29 2007, 06:38 PM
Ok, so the popular opinion suggests an exhaust leak... I recently put in new copper gaskets, filed the tops of the exhaust manifolds down equally, and used the correct copper plated exhaust nuts...No spinning studs, all is tight. What gives? I know there is a slight leak at the gasket where the manifold meets the muffler, but the sound coming from that is not the sound I am hearing.
Lo-Fi Version | Time is now: 20th June 2024 - 05:36 AM |
