rfuerst911sc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States ![]() |
I am in the process of converting to 911 ebrakes. I have done a search and there is lot's of good info and pics. I have done the grinding to get the ebrake hardware to fit the 914 hub. I have it all mounted. I have fabbed and welded the stationary piece that the ebrakes have to stop against. However what I can't figure out from the pics is what are the rough dimensions of the transition/bell crank piece? I have moved the OEM cable mounts so I know where the cable will end and I have left room for the swing arm to do its thing but my head is stuck on this bellcrank. Can anyone give me the dimensions of the pieces they fabbed? And what did you use for raw stock? I am brain dead on figuring this out (IMG:style_emoticons/default/dry.gif)
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Why use a bellcrank? Cables are cheap from the local boat shop.
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
Why use a bellcrank? Cables are cheap from the local boat shop. 1. Because I already had 914-4 cables in good condition. 2. To keep replacement parts easy to source and off the shelf. 3. Because I can. I would have to go measure mine to tell you the dimensions of my belcrank arms, but I believe that they are approximately 2" from the pivot. Like Aaron mentioned, you could make a ratio out of the crank arm to minimize the e-brake lever travel, but mine are 1:1. So Rich Johnson makes a kit for this? Maybe we should "oust" the ripoff (just kidding). If Rich makes a kit, I'm sure it is a good one, but I made mine myself. You could also do a web search for Phoenixhobbies.com Good luck with it. They do work well. Attached image(s) ![]() ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 10:06 AM |
