rfuerst911sc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States ![]() |
I am in the process of converting to 911 ebrakes. I have done a search and there is lot's of good info and pics. I have done the grinding to get the ebrake hardware to fit the 914 hub. I have it all mounted. I have fabbed and welded the stationary piece that the ebrakes have to stop against. However what I can't figure out from the pics is what are the rough dimensions of the transition/bell crank piece? I have moved the OEM cable mounts so I know where the cable will end and I have left room for the swing arm to do its thing but my head is stuck on this bellcrank. Can anyone give me the dimensions of the pieces they fabbed? And what did you use for raw stock? I am brain dead on figuring this out (IMG:style_emoticons/default/dry.gif)
iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
I use an oil bronze bushing as my pivot. I think design may have something to do with other bell crank setups not working properly. My pull is straight and short, I dont see any problems with binding but we will see...
I did consider the cable sheath design but didnt like the idea of the cables making that big U turn under the exhaust. A motorcycle throttle cable sheath with a 90 degree bend in the sheath maybe the cable answer to that. |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
I use an oil bronze bushing as my pivot. I think design may have something to do with other bell crank setups not working properly. My pull is straight and short, I dont see any problems with binding but we will see... I did consider the cable sheath design but didnt like the idea of the cables making that big U turn under the exhaust. A motorcycle throttle cable sheath with a 90 degree bend in the sheath maybe the cable answer to that. I have not burned a cable in 2 years of use. But I agree, I don't like the cable that close to the exhaust either. |
Lo-Fi Version | Time is now: 26th June 2024 - 10:15 AM |
