adjusting the shift linkage |
mrhurtalot |
Sep 29 2007, 09:22 AM
VRRRRRRROOOOOOOOOM! Group: Members Posts: 323 Joined: 5-October 06 From: Yukon, Oklahoma Member No.: 6,996 |
need as much info as possible, looked on pelicans, nothing, IPB searches dont ever work well on here! haha.
this is desperately urgent, this may be my last weekend to drive her. so today is a total work day for me. (IMG:style_emoticons/default/smile.gif) TIA (IMG:style_emoticons/default/welder.gif) |
drew365 |
Oct 3 2007, 09:38 PM
These are the good old days! Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 |
After you disconnect the shifter from the rod, you should be able to rotate the rod through the rear tunnel opening about 1/4" clockwise and counterclockwise. If you turn the rod clockwise and then tighten the shifter back up while holding the rod in that position you should be able to access 4th and 5th easier. There's a point where you will lose your ability to catch R and 1st if you go too far. I usually take tools with me and do this while driving around the neighborhood until I find the sweet spot in the middle. I drive a little, see how it shifts, pull over and adjust and repeat. Moving the rod forward and aft will also make going into 2nd and 3rd easier or harder. Driving the car right after making an adjustment is the best way to get a feel for how to do it.
Rotate clockwise: R and 1st harder, 4th and 5th easier Rotate counter clockwise: R and 1st easier, 4th and 5th harder Pull shaft back from shifter: 2nd easier, 3rd harder Push shaft forward into shifter: 2nd harder, 3rd easier |
Lo-Fi Version | Time is now: 24th June 2024 - 07:34 AM |
