jonferns |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States ![]() ![]() |
was considering a 2.7-ish engine for a shell that I have. After reviewing what is necessary, I am starting to think that a big four is sufficient.
what is the normal power output for a 2056, and can that setup run on FI? looking for something with a bit more power than what we have. Currently have a spare 2.0 out of a '75/'76 sitting in the garage... thanks! -JON |
DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
I built a 2056 using 96mm KB aluminum pistons, and a 9550 cam from Jake.
all my other parts were machined locally and used. Had my stock Mahle 2.0L cylinders punched out to 96mm. Heads rebuilt with SS valves, HD valve springs, new guides and seats. Case was align bored, crank was polished and specd, all the usual stuff. Total cost of rebuild was just around $2K. then I had all the engine tin bead blasted and repainted. here are a few shots of what I got. And yes I am running stock D-jet with great results....check the standings for 914cup at the top of the page. (IMG:style_emoticons/default/biggrin.gif) Attached thumbnail(s) ![]() Attached image(s) ![]() ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 06:56 AM |
