What is the curent thinking on exhaust stud nuts, Copper or regular? |
thomasotten |
Oct 10 2007, 10:52 AM
Senior Member Group: Members Posts: 1,550 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
Are the copper coated nuts the way to go, or is using regular bolts, double bolting the way. I read something yesterday that said the copper nuts should only be used once...why?? Should I coat the studs with anything?
davep |
Oct 10 2007, 03:16 PM
914 Historian Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Jake has said in the past that he uses stainless steel nuts in pairs (double-nutting). I've seen them on his web-catalog. Pretty cheap if you buy a bag of 25. Then use more for the muffler. I assume they also work well for the HD rocker studs and the regular intake studs, so you can use up a bag or two very quickly.
Lo-Fi Version | Time is now: 26th June 2024 - 07:16 AM |
