Jeff Hail |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 ![]() |
Bringing Out The Dead.....or how to restore a rusty 914 and convert it to a street/track car when I have time after dealing with everyone elses stuff.
My background is collision and restoration (day job) of high end automobiles for 28 years in addition to race fabrication. I jumped the fence and left that industry to pursue pretty much the same thing except on the paperwork end which is really boring and thankless. (another day job) I look at rust like a diamond in the rough. Rust is afraid of me because it know's it cannot live in my world. Metal becomes submissive because I have confidence in my metal working talents. I will add to this post as work progress's. I hope my years of experience can help others as I add. I believe there is a right way to repair a car and wrong way. I metal finish because in the end its cleaner, lighter and stronger. I was taught old school techniques with new school technology. A great combination. I also believe in doing a job once correctly using the highest quality materials and proper tools. Many ways to skin a cat I say. If you hold it by the tail it can still bite! Good advice to follow: Take measurements of the door openings and targa bar to windshield header. Cross measure then do it again to confirm. Recheck your measurements against the factory figures. Make a couple of adjustable braces for each side that attach from the upper seat belt anchors to the door hinges. I recommend cross braces also right to left. These can be made from rod or tube and turnbuckles for cheap. Racer Chris has some really nice ones with rod ends. Support the car from below equally on both sides of the undercarriage and front and rear. I do not believe jack stands can hold the proper tolerances at 4 points. It takes a minimum of 6 and preferably 8. These are all easy to do and are essential to a square and level chassis. Not everyone can afford a Cellete bench or hourly frame time at a shop for these type of do it yourself repairs. Impovisation can be done correctly and for a lot less money. Make sure your floor or platform is level. Keep in mind that tolerances for the 914 were 7-9mm from the factory so anything you can do to make it better is worth it. 7mm by today’s standards is huge. 9mm is a Grand Canyon. Anything you can do to tighten the tolerances will provide a better end product. Exterior panels were fit with the adjust and weld method and are only a skin. My 914 had measurements all over the place on the front end and the rust issues were all in the rear that needed correction. Car was never in any collisions. 90% of the measurements were factory assembly tolerances. Porsche's aint perfect. I made my own dedicated bench for 911's and 914's. By some stroke of luck I ended up with a 1 mm variance in height (datum) and 2mm in length and width is zero with my own fixtures. This has been substantiated with endless anal cross measuring and factory manuals. I used a steel front suspension cross member as a front body holding fixture. I went through 4 before I found an acceptable one. The first 3 were so far off factory tolerances (4-6 mm out of square) I rejected them before I found a good one. My bench is not for pulling. It was designed for assembly and replacement of structural parts. It will support 3,000 pounds. $350 worth of steel and another $175 in industrial castors was worth it considering its use. A stripped 914 shell is a feather and easy to roll around. When you cut and replace structural parts recheck your measurements. Control points change when you remove, replace and weld in new parts. They are easily controlled with patience. If it does not come out perfect do not lose sleep. Remember tolerance and variance was not perfect from the factory. If you have a control point locating hole that is 14 mm a dowel or pin of 9-10mm was used during birth. That is why suspension systems are adjustable for variance and wear. You will also find center indexing points on the front and rear of the body. Easy tools to use are plumb lines, tape measures and levels if you do not have access to high end measuring equipment. You can locate and make symmetrical measurements throughout repairs. If you have one side that is undamaged or not rusted use that side as a starting point for measurements. Use panel gaps as a visual indicator during repairs and welding. 3 important factors- height, length and width. If you are me then there are 4 (Z axis) and that one will make you lose sleep! Some pics of the beggining: A back east 914 comes to California. Attached image(s) ![]() ![]() ![]() ![]() |
type11969 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States ![]() |
Jeff- nice work, just figured out that you were the same jeff that posted in my thread! Those underbody jigs are nice . . . wish I had them. I may have to pick your brain at some point to figure out a way to line up the front suspension points on my 914. It was in an accident and the drivers quarter (and then some) was replaced right up to the suspension mounting point. It has to have been knocked out of alignment, if not by the accident, then certainly by the (poor) welding.
Keep up the good work! -Chris |
Jeff Hail |
Jeff- nice work, just figured out that you were the same jeff that posted in my thread! Those underbody jigs are nice . . . wish I had them. I may have to pick your brain at some point to figure out a way to line up the front suspension points on my 914. It was in an accident and the drivers quarter (and then some) was replaced right up to the suspension mounting point. It has to have been knocked out of alignment, if not by the accident, then certainly by the (poor) welding. Keep up the good work! -Chris Chris, My 914 has had the right rear suspension console repaired in it's life. It has gobs of welding on the right side. It looked as if it had one of Racer Chris's ear reinforcements installed. It was never treated for corrosion so it rusted out badly. A big 3 inch washer had been welded in to gain some life on the inner ear. It was pretty bad. A dust pan full of rust came out when I cut the console off. It's getting lighter by the day! Before any cutting I took some measurements. All 914's seems to have some variance at the suspension mounting area's in as much as 1/2 inch measured center to each side. I measured from the center hole at the upper firewall just above the lower firewall seam to the inner console bolt hole. Considering how much rot the right rear console had no sag was found and was equal side to side. The measurement was 28-1/4 from the firewall hole to the front edge of the console bolt hole. I prefer center to center hole measurements but the right console was so far gone I couldnt rely on it. Side to side from inner console to inner console was 33-1/2 from outside to outside on the bolt hole. I have some measurements from 914World, Pelican and an old Mitchell book. I have still been trying to locate datum (height) measurements to no avail. A this point I am not worried as my car still has consistency side to side. The jigs are a plus as it provides support and a reference point for location with no flex. The body is so light stripped nothing moves. My front suspension control points were not perfect from the factory. The forward bracket on the body that locate's the front suspension crossmember was about an 1/8 to far back on the right side. The bracket on the suspension crossmember has slotted holes that go to the rear mount so it still fits without binding. A lot of caster and camber adjustment is available on the strut tower it probably doesnt make much difference but I decided to remove and reweld the bracket where it should have been for proper Steering Axis Inclination. My car has not had any structural damage from collision which is a plus but the rust work is plenty to keep me busy. |
type11969 |
Jeff-
Thanks for the info. I've tried using the pics on this site before but they are so blurry that it is sometimes tough to figure out what is what. I have plenty to contend with in the rear first before I start worrying about the front again though . . . -Chris Jeff- nice work, just figured out that you were the same jeff that posted in my thread! Those underbody jigs are nice . . . wish I had them. I may have to pick your brain at some point to figure out a way to line up the front suspension points on my 914. It was in an accident and the drivers quarter (and then some) was replaced right up to the suspension mounting point. It has to have been knocked out of alignment, if not by the accident, then certainly by the (poor) welding. Keep up the good work! -Chris Chris, My 914 has had the right rear suspension console repaired in it's life. It has gobs of welding on the right side. It looked as if it had one of Racer Chris's ear reinforcements installed. It was never treated for corrosion so it rusted out badly. A big 3 inch washer had been welded in to gain some life on the inner ear. It was pretty bad. A dust pan full of rust came out when I cut the console off. It's getting lighter by the day! Before any cutting I took some measurements. All 914's seems to have some variance at the suspension mounting area's in as much as 1/2 inch measured center to each side. I measured from the center hole at the upper firewall just above the lower firewall seam to the inner console bolt hole. Considering how much rot the right rear console had no sag was found and was equal side to side. The measurement was 28-1/4 from the firewall hole to the front edge of the console bolt hole. I prefer center to center hole measurements but the right console was so far gone I couldnt rely on it. Side to side from inner console to inner console was 33-1/2 from outside to outside on the bolt hole. I have some measurements from 914World, Pelican and an old Mitchell book. I have still been trying to locate datum (height) measurements to no avail. A this point I am not worried as my car still has consistency side to side. The jigs are a plus as it provides support and a reference point for location with no flex. The body is so light stripped nothing moves. My front suspension control points were not perfect from the factory. The forward bracket on the body that locate's the front suspension crossmember was about an 1/8 to far back on the right side. The bracket on the suspension crossmember has slotted holes that go to the rear mount so it still fits without binding. A lot of caster and camber adjustment is available on the strut tower it probably doesnt make much difference but I decided to remove and reweld the bracket where it should have been for proper Steering Axis Inclination. My car has not had any structural damage from collision which is a plus but the rust work is plenty to keep me busy. |
Lo-Fi Version | Time is now: 3rd April 2025 - 07:53 PM |
