> Testing injectors, ?
Hammy
post Oct 16 2007, 10:09 PM
mr. Wonderful
How do I do a visual test/check on fuel injectors outside the car on the bench? Any way to tell they're spraying right? I don't want to install this engine and find the injectors are crap.
Twystd1
post Oct 16 2007, 10:54 PM
You don't want to know... really.....
Zack,
I would send em out for testing if you REALLY want to be clear if they are in good shape.
I think you will probably find out you will need to send in 6-8 injectors to get a matching set of 4 good ones. This assumes you are using original injectors from 1976 or earlier.
I won't use RC injectors anymore. Too may complaints from the ricers.
You may want to change your post to read....
Who knows of an INJECTOR TESTER IN THE MODESTO AREA.
Cause you probably don't have the facility's to REALLY test them at home.
YOU COULD hook em up to your engine's fuel system. Ground the coil wire. (KEEP SPARK AWAY FROM FUEL)
Get yourself a glass jar and watch the spray. At least that will tell you if it has a pattern or is just puking fuel.
The best approach is to send em out to a pro. IMnonHO.
Cheers,
Clayton
Hammy   Testing injectors   Oct 16 2007, 10:09 PM
Twystd1   Zack, I would send em out for testing if you REAL...   Oct 16 2007, 10:54 PM
Hammy   Zack, I would send em out for testing if you REA...   Oct 16 2007, 11:04 PM
Twystd1   Theres a place in San Diego that does it cheap AND...   Oct 17 2007, 12:12 AM
Hammy   Theres a place in San Diego that does it cheap AN...   Oct 17 2007, 01:37 AM
orange914   have you checked the fuel injection shop on 9th st...   Nov 9 2007, 10:10 PM
Spoke   I'm in the same boat trying to get a FI system...   Oct 17 2007, 06:53 AM
blitZ   I had this place refurbish my injectors. They wil...   Oct 17 2007, 07:40 AM
type11969   Has anyone ever had any luck using a modern inject...   Oct 17 2007, 07:56 AM
BMartin914   You can buy an injector testing unit which will fi...   Oct 17 2007, 08:21 AM
slim72914   Actron makes an injector pulser so you can simulat...   Oct 17 2007, 09:42 AM
BMartin914   Actron makes an injector pulser so you can simula...   Oct 17 2007, 07:27 PM
jk76.914   I've tested mine a couple of times. Generally...   Oct 17 2007, 08:09 PM
jimkelly   www.witchhunter.com cleans the worst looking injec...   Nov 6 2007, 10:23 PM
p914   In Portland there's a place Automotive Product...   Nov 7 2007, 01:46 PM
toon1   Has anyone ever had any luck using a modern injec...   Nov 10 2007, 10:08 AM
type11969   What injectors work and what are the modifications...   Nov 11 2007, 03:14 PM
euro911   Have any of you cleaned your injectors by dunking ...   Nov 10 2007, 11:27 AM
toon1   That may work, what happens to the inj's is th...   Nov 10 2007, 12:21 PM
toon1   What injectors work and what are the modification...   Nov 11 2007, 04:52 PM
yarin   Checkout Cuzin Performance. http://www.cruzinper...   Nov 11 2007, 07:13 PM
- Lo-Fi Version Time is now: 26th April 2025 - 08:52 PM
