Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,827 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California ![]() |
How do I do a visual test/check on fuel injectors outside the car on the bench? Any way to tell they're spraying right? I don't want to install this engine and find the injectors are crap.
Twystd1 |
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,515 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 ![]() |
Zack,
I would send em out for testing if you REALLY want to be clear if they are in good shape. I think you will probably find out you will need to send in 6-8 injectors to get a matching set of 4 good ones. This assumes you are using original injectors from 1976 or earlier. I won't use RC injectors anymore. Too may complaints from the ricers. You may want to change your post to read.... Who knows of an INJECTOR TESTER IN THE MODESTO AREA. Cause you probably don't have the facility's to REALLY test them at home. YOU COULD hook em up to your engine's fuel system. Ground the coil wire. (KEEP SPARK AWAY FROM FUEL) Get yourself a glass jar and watch the spray. At least that will tell you if it has a pattern or is just puking fuel. The best approach is to send em out to a pro. IMnonHO. Cheers, Clayton |
Hammy |
Zack, I would send em out for testing if you REALLY want to be clear if they are in good shape. I think you will probably find out you will need to send in 6-8 injectors to get a matching set of 4 good ones. This assumes you are using original injectors from 1976 or earlier. I won't use RC injectors anymore. Too may complaints from the ricers. You may want to change your post to read.... Who knows of an INJECTOR TESTER IN THE MODESTO AREA. Cause you probably don't have the facility's to REALLY test them at home. YOU COULD hook em up to your engine's fuel system. Ground the coil wire. (KEEP SPARK AWAY FROM FUEL) Get yourself a glass jar and watch the spray. At least that will tell you if it has a pattern or is just puking fuel. The best approach is to send em out to a pro. IMnonHO. Cheers, Clayton Thanks Clayton.... any idea how much that'll run me ? I'm runnin' low on the 914 funds (IMG:style_emoticons/default/wink.gif) I was hopin' to install this weekend but maybe it'll have to wait... The guy SAID the FI system was working perfect, but the injectors look perty rough as is. And I only got 4. How do I source good used ones for a reasonable price if need be? |
Lo-Fi Version | Time is now: 26th April 2025 - 08:57 PM |
