VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
So, at the Sterling meet I did a leakdown test on my motor, and found a problem with Cylinder 1. 45% leakdown, but 120 lbs of compression. Was tempted just to let sleeping dogs lie, but pulled the head off.
What was going on was clear as soon as we did that, the head was not totaly sealed to the cylinder, off by a very small amount. Instead of having the head recut, I decided to try and lap the two of them together. So, last night I hand lapped them, using ground graphite to check for even contact. I got good contact after the third round of hand lapping (lap, clean, check). Now I need to get the jug back on the block. I have a ring compressor on the piston, but I can't ficgure out how to get the head back on. Do I have to take the piston head off the rod? If so, how do I get it off. It looks like that tis a spring keeper that needs to be removed. Is there anyhting on the rod the needs to be loosened before I can pull the pin out to remove the piston head? Obviously, if there is a trick to getting the jug back on without pulling off the piston head, I'd like to do that. Zach |
DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
I think Jake has cases routinely decked now so every part of the cylinder register is equal distance from the case parting line. I think with kits the builder is responsible for this. This leaves no irregularities that affect the seating of the cylinders to the case. As important, all cylinders start the same distance from the centerline. If the cylinders are clean and the same height, the deck will be the same and if the sealing surface of the heads are equal, it should seal better. It removes a variable. Spending a week with Jake taught me it's all about reducing variables and getting things clean. The hobbist can control some of this but, not all. Jake's remove some of the variables especially regarding the combination of parts.
Dave |
Lo-Fi Version | Time is now: 25th June 2024 - 10:12 PM |
