> Installed an EGT Gauge today..., Only took 10 minutes
McMark
post Nov 3 2007, 07:29 PM
914 Freak!
I've had this Exhaust Gas Temp gauge sitting around for a couple months and while I had the car up on ramps getting a new fuel filter (and it needed it!) I decided to pop this guy in place.
I got the parts from Aircraft Spruce, this guage, this clamp-on probe, and this 15' extension cable. All told, I spend around $100. This gauge has the benefit of being semi-original looking, ambient temperature compensated, and matches my Micro1000 CHT gauge.
All I did to install it was drill a small hole in the exhaust tube, and insert the probe, tightened everything down, attached the cables and ran them to the cabin.
I drove the car around the block, which was very interesting. My car has been running very poorly ever since returning from the RRC, and I thought it was just the fuel filter. But it's not. It was very interesting to watch the needle moving as I opened and closed the throttle and it also helped me visualize the problem that I'm having. My car has been intermittently losing power, and I would be driving along at a nice EGT, and the car would lurch, and I would look over and the EGT was extremely low. And since it is my understanding that EGT is more affected by timing than AFR, I can be pretty confident that for some reason my timing is wonky. This may be the KitCarlson EFI dying or a bad wiring harness connection. It might be time to *GASP* install a spare set of carbs and a Mallory. (IMG:style_emoticons/default/ohmy.gif)
This was an affordable and easy upgrade. I expect that it will be a useful tool for tuning the motor and if anyone has an extra gauge slot to fill, I would recommend an EGT after you have a CHT.
Rand
post Nov 3 2007, 07:53 PM
Cross Member
This stuff is interesting to me. If for nothing else than the educational factor, I want to put both an EGT and AFR gauge in and learn how to optimally tune an engine - carbs and FI.
Thanks for sharing this Mark. Good to know about some parts options with ballpark pricing.
For those who have had experience with AFR gauges, what do you recommend? Clearly it should be wideband, but what kits exactly and what are good prices? Any thoughts on this NGK unit? -> http://www.powerdex.com/
McMark   Installed an EGT Gauge today...   Nov 3 2007, 07:29 PM
TimT   Timing does affect EGT but not as drastically as y...   Nov 3 2007, 07:43 PM
Rand   This stuff is interesting to me. If for nothing el...   Nov 3 2007, 07:53 PM
McMark   I have an Innovate Motorsports LM-1 that will get ...   Nov 3 2007, 08:42 PM
ConeDodger   I have an Innovate Motorsports LM-1 that will get...   Nov 3 2007, 09:49 PM
McMark   B)   Nov 3 2007, 11:28 PM
restore2seater   Mark, Is this the same CHT gauge you are using...   Nov 4 2007, 12:19 AM
McMark   I have absolutely no complaints about it. Install...   Nov 4 2007, 12:49 AM
toon1   What are your EGT temps.? What is good temps for ...   Nov 4 2007, 01:12 AM
McMark   According to my reading on the RAT Forums, 1275 is...   Nov 4 2007, 01:16 AM
ConeDodger   According to my reading on the RAT Forums, 1275 i...   Nov 4 2007, 01:25 AM
gregrobbins   I have the O2 sensor bung welded on my header and...   Nov 4 2007, 10:45 AM
type11969   I've got an LM-1 with the aux box, it lets you...   Nov 5 2007, 09:03 AM
McMark   The EGT probe is very small. You would have to cu...   Nov 4 2007, 01:35 AM
ConeDodger   The EGT probe is very small. You would have to c...   Nov 4 2007, 03:40 PM
blitZ   Interesting info. How close to the head must the ...   Nov 4 2007, 10:03 AM
McMark   With all the talk of 'cold-junctions' and ...   Nov 4 2007, 02:06 PM
blitZ   IIRC, the thermocoupler measures the difference in...   Nov 4 2007, 03:29 PM
McMark   :rotfl: Don't poke a sleeping.... um.... well...   Nov 4 2007, 05:14 PM
ConeDodger   :rotfl: Don't poke a sleeping.... um.... wel...   Nov 4 2007, 09:03 PM
Aaron Cox   a switch has resistance...... so your true CHT re...   Nov 4 2007, 09:15 PM
TimT   Aaron, Mark, you can extend an egt harness, you n...   Nov 4 2007, 11:06 PM
McMark   Huh... Neat! :D But that's a special sw...   Nov 4 2007, 11:08 PM
ME733   ............Well aircraft spruce is a good source ...   Apr 12 2010, 08:57 AM
Jake Raby   If ind that the TIV engine is VERY responsive at W...   Apr 12 2010, 10:18 AM
ME733   ...westach...is available at aircraft spruce.....a...   Apr 12 2010, 06:51 PM
Racer Chris   Westach is cheap. You get what you pay for.   Apr 12 2010, 08:01 PM
- Lo-Fi Version Time is now: 7th January 2025 - 09:31 PM
