> timecert question, helicoil uncoiling
VaccaRabite
post Nov 6 2007, 02:31 PM
En Garde!
The skinny:
Spark plug helicoil is going bad - uncoiling out of the socket. I know that I want to timesert it to fix the problem.
BUT
Since the socket has a helicoil in it (that needs to come out) what size timecert do I need to get?
ALSO
How do I get the bad helicoil out of the head without doing further damage to the head? The head is off the engine, so I am not worried about bits of coil falling into the cylinder.
This site has MANY sert options, but I don't know which one I need. HELP?!
http://www.timesert.com/html/sparkplug.html
Thanks
Zach
tdgray
post Nov 7 2007, 04:31 PM
Forgive my total ignorance... what is the difference between a timecert and a helicoil.
You may throw the rocks now... (IMG:style_emoticons/default/dry.gif)
VaccaRabite
post Nov 7 2007, 04:57 PM
En Garde!
QUOTE(tdgray @ Nov 7 2007, 05:31 PM) *
No problem.
A helicoil is a coil of wire (think a tubular spring) that threads into the socket, giving the bolt or spark plug something to thread into. They are great for things that don't get removed all that often, like head studs and the like. With spark plugs, they tend to start coming apart after a while.
A time cert is a solid steel socket that replaces the old threads. They last a lot longer then coils, as they are solid.
To sum up. Timeserts are solid metal. Helicoils are wire.
Zach
Vacca Rabite   timecert question   Nov 6 2007, 02:31 PM
Cap'n Krusty   You need a 3/4 inch long spark plug insert (14mm x...   Nov 6 2007, 03:46 PM
Joe Ricard   Yea what the crusty one said.   Nov 6 2007, 04:23 PM
HAM Inc   Make sure you grab the tag end at the outside of t...   Nov 6 2007, 05:39 PM
jimtab   Make sure you grab the tag end at the outside of ...   Nov 6 2007, 11:54 PM
slim72914   NO NOT YANK it out! you should be able to turn...   Nov 7 2007, 09:08 AM
root   I have installed a blue million TimeSerts and hav...   Nov 7 2007, 10:36 AM
Dr Evil   Len, thanks for posting your expertise here :D I a...   Nov 6 2007, 08:01 PM
root   Len, thanks for posting your expertise here :D I ...   Nov 7 2007, 10:32 AM
Vacca Rabite   The 14mm x 1.25 inserts come in multiple lengths. ...   Nov 6 2007, 09:23 PM
HAM Inc   Thanks Dr. Evil. I'm happy to be of service...   Nov 7 2007, 09:57 AM
Vacca Rabite   Sweet jesus! $150 for the install tooling...   Nov 7 2007, 11:26 AM
root   Sweet jesus! $150 for the install toolin...   Nov 7 2007, 02:44 PM
Vacca Rabite   What size tool do you need? If you can let me k...   Nov 7 2007, 05:02 PM
root   What size tool do you need? If you can let me ...   Nov 8 2007, 07:50 AM
tdgray   Forgive my total ignorance... what is the differen...   Nov 7 2007, 04:31 PM
Vacca Rabite   Forgive my total ignorance... what is the differe...   Nov 7 2007, 04:57 PM
GS Guy   Zach, Be sure to contact Timesert directly before ...   Nov 7 2007, 05:07 PM
Gint   Zach, Be sure to contact Timesert directly before...   Nov 8 2007, 08:15 AM
Dr Evil   Zach, Check with the old guys you bought your wind...   Nov 7 2007, 06:26 PM
Vacca Rabite   Zach, Check with the old guys you bought your win...   Nov 7 2007, 08:53 PM
Dr Evil   Nope, he is strictly salvage parts, not service. D...   Nov 7 2007, 09:29 PM
root   Zach, I pm'd you! :type:   Nov 8 2007, 09:43 AM
- Lo-Fi Version Time is now: 26th December 2024 - 08:31 PM
