914chris |
Newbie ![]() Group: Members Posts: 23 Joined: 30-August 05 From: Santa Clarita, CA Member No.: 4,701 Region Association: None ![]() |
I have an original 2.0 liter six. I bought a 3.0 liter with webers and am going to do the swap. I have researched this forum and what to confirm/clarify if I am getting things right.
From what I understand I need to do the following: 1) Get a flywheel/clutch setup from Kennedy. Can I use the 3.0 liter flywheel with an adapter? It is a 9 bolt flywheel. Is there a reason to use the flywheel from Kennedy, over the adapter ring gear? I have read that the Kennedy flywheel is welded up and re-drilled, not sure if I want to go that way. 2) Modify the 3.0 liter oil cooler with a 90 degree to clear the trailing arm. Is the 3.0 liter cooler different than my cooler from the stock 2.0? Do I need the engine cooler even if I want to add a front mounted cooler? Will I need a front mounted cooler? 3) Do I need to modify the throttle linkage on the 3.0 liter? It came out of a 911. I would think I need some of my linkage parts from the original six, but not sure. I plan to upgrade the fuel lines in the tunnel with the stainless setup from one of the guys on the board. Is there anything else I should do while I have things apart? Thanks for you help. |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
why not just take the 914-6 oil cooler of the old engine and put it on the new?
Lo-Fi Version | Time is now: 18th June 2024 - 07:12 AM |
