TJB/914 |
Mid-Engn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,340 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest ![]() ![]() |
Hi Guys,
I just finished drilling (2) 6mm holes & (1) 3mm hole in by trunk to mount my "Rear Fog Light" factory accessory. I like it, makes my car different from all the others. (IMG:style_emoticons/default/pray.gif) Here's a few pictures to show details of the U.S.A. issue rear fog lamp I installed. I got a Euro fog lamp assembly from Gustl (thanks Gustl-aka-Wolfgang) & put everything together using the satin black U.S. housing with the Euro lens because I thought it looked better. One of the brackets to mount is still available from Porsche, but the exterior bracket is NLA. The exterior bracket I got from Gustl was a surprise, it's made of stainless steel. I'll post a number of photo's in a few days showing lots of details & differences. (IMG:style_emoticons/default/popcorn[1].gif) Hope you guys enjoy. Tom BTW Pat: I measured a lot before drilling the holes. Attached thumbnail(s) ![]() ![]() ![]() Attached image(s) ![]() ![]() |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Good point. Then what about a ring connector to go under a nut on the inside support plate. That is an M6 nut. The ground wire could be several inches shorter as a result.
Lo-Fi Version | Time is now: 26th June 2024 - 11:38 AM |
