GT40-914r |
Newbie ![]() Group: Members Posts: 17 Joined: 26-June 05 From: sanbernardino so. cal. Member No.: 4,331 ![]() |
FS /-fresh 1976 914-6 conversion ...Dressed in black
Okay ! here you go Sold /Sold/Sold ---------- Destination : United Kingdom (IMG:style_emoticons/default/smilie_pokal.gif) To a Great Fellow 914-6 rrrr Cheers ..to Kevin (IMG:style_emoticons/default/welcome.png) And a grip of thanks to all you fellow 914rrrs that have given me great advice and support !!!! Now ! ...onto my 914-8 Based 914-GT-40 MK1 project ... (IMG:style_emoticons/default/welder.gif) NEW digital pictures were just added check out pages 4 and 5 new digi shots ... this is a great loss to me ... and your gain !!!! shippings services available ..anywhere in the US and Canada and UK Very sweet ..Tight street or event car ...Chassis # NR 5039049 -Title #4762904071 Porsche-6 cyl- 2.2 Has a fresh rebuild with test and tune miles only Restoration and conversion -3 years Weber triples - 40 IDA Webers - tight throttle shafts Screened velocity stacks PowerPlant 69 2.0 magnesium Block / `bottom end -case #6290505 with 2.2 heads # K1819d / 7-1967 / 8-1967 /901-104-306.OB valves 38x42mm Bore 83.98 @ 2.2 Webb S cams New style Hydraulic Tenssioners have been installed New German PP / new pilot bearing New Stage 1 Clutch disc 911-header/exhaust system ... produces good mid range performance and Hirevving tourque curve ...wonderful song 914-6 conversion has less than -50- miles since car and engine were completed Jan 07 original California car ...with fresh simple updates .... I have found a small amounts of "surface rust" in the normal areas....No Holes were found longitudinals were fine and New chassis undercoating everywhere Pan has a few bottoming indents ..nothing to get twisted about pics of any area available ....on request New High capacity racing-11.5 qt aluminum oil tank with high flow oil cooler installed fully aero quipped .. with #12 A&N .SS high pressure lines were installed Billet anodized New Hamberger-dual high volume alum billlit sysfr- with dual FR-1 racing filters New Hi flow oil cooler fully 12 A&N Aero quipped SS New HP- SS braided .oil lines 911-wrapped headers with baffled stingers New Battery Givani Racing Rims - 17x7s + 40mm offsets Tires 205-40-17 s (summer compounds) New jet black paint (Stripped to metal / epoxy base primed ) very proffesionaly done NEW Complete custom interior / deep ferrari red / Pitch Black New Plush -Black Carpets New APC racing seats - comfortable JVC / New 350 watt Stereo system /12"Vega sub wfr / 2 5x7s / 2 HGs big thumpin sound ..nice New light wght fully adjustable Aluminum rear wing Light wght doors Light wght early- front and rear bumpers included front & rear sway bars - solid ball joints -solid New rear drop link .urethanes New Super Comp - Carbon Fibre Face Tach w/ external redline Light center console - working clock short shifter New cutch cable New throttle cable New Facet electric pump New CVs and rubber boots -4 New trans fluid change Used spare set of light wght glass bumpers ( early style ) New Dash cover Special front & rear glass Tints - chrome to black New Led -Modem style side view mirrors Rear Louvered engine lid .for better air flow New Chrome engine lid Grill Targa Top Refinished in black epoxy - to match car targa top - fits in trunk as needed New rear Brake proportioning valve New rear brake lines and flex lines good luck .. (IMG:style_emoticons/default/smilie_pokal.gif) Sir Lawrence Attached image(s) ![]() ![]() |
GT40-914r |
3/4 view
Attached image(s) ![]() |
Lo-Fi Version | Time is now: 28th June 2024 - 01:21 PM |
