| toon1 |
May 17 2007, 07:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I've been working on retrofitting newer fuel injectors for the 914. My goal was to find an injector that can utilize as many of the stock parts as possible.
I came up with a inj. off a 96 forn escort 1.8l motor. One comment is needed, this will only work with an aftermarket FI system s these inj. are HIGH inpedence. This setup gives the ability to use higher fuel pressure, 44psi . It has a lower flow rate than the stock inj.. so the pulse widths will be longer and should give a little better idle quality. these are disc style rather than pintle( stock). fuel atomization will be much better giving a cleaner, more efficiant burn. The length of the inj. where shorter than stock so I added an O ring to make up the difference. The plastic tips are different ,I cut them off and put the tip of the stock inj. on the new inj., fit perfect. now the stock tip O ring can be used. the fuel rail was machined to tolerance for the top O ring seal. And I made a bracket to support the fuel rail from vibration and also keeping it from popping off the top of the inj. Here's the setup assembled. enjoy Attached image(s)
| toon1 |
Nov 24 2007, 12:35 AM
I did some calculations with the ford escort inj. and determined they were a bit too small.
After running the calcs., I did some work with MS on stim and With the flow rates of that inj., the duty cycle at WOT. was about 115%. The FP would have had to been run at about 55psi to get the flow rate for 85% at WOT. I had a set of four inj. from a ford probe INP480's. The flow rate was hard to find but it flowed about 21lbs/hr, about the same as the stock inj. but at 43psi. After running those #'s on MS and the stim, it looked good. I had pw's at idle around 2.2ms. these will also give the latatude to lower the FP, if needed and not hurt the fuel atomization. The probe inj's had a smaller top so I made some new rails with smaller holes. otherwise everything else fit the same as the escort inj's. The connectors where no prob., I just cut them off the wire harness of the probe. they fit just fine with the inj's. in the rails. I have not put them on the wire harness yet but will soon. with the inj's. on the air intake runners which are installed on the motor, it all looks good (IMG:style_emoticons/default/biggrin.gif) I am also retrofitting an EDIS system to the motor,direct coil drive so I have to add a 2nd coil driver. The engine parts took forever to get back from the machinest(4months!). Right now the engine is built and close to being ready for install. Unfortunatly I have run into probs. with my truck. The tranny had to be replaced and also the intake man. gaskets so it has be occupiing my time for the past few day's The car is still a way's off from running but I am anxious to get it going. Keith |
| yarin |
Nov 24 2007, 11:40 AM
'14-X'in FOOL ![]() ![]() ![]() Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I did some calculations with the ford escort inj. and determined they were a bit too small. After running the calcs., I did some work with MS on stim and With the flow rates of that inj., the duty cycle at WOT. was about 115%. The FP would have had to been run at about 55psi to get the flow rate for 85% at WOT. I had a set of four inj. from a ford probe INP480's. The flow rate was hard to find but it flowed about 21lbs/hr, about the same as the stock inj. but at 43psi. After running those #'s on MS and the stim, it looked good. I had pw's at idle around 2.2ms. these will also give the latatude to lower the FP, if needed and not hurt the fuel atomization. The probe inj's had a smaller top so I made some new rails with smaller holes. otherwise everything else fit the same as the escort inj's. Keith Hey Keith, What were the flow #s for the Ford Escort injectors that you determined were too low? (15-16 lbs/hr?) Stock injectors flow: Yellow (1.7L) - 265 cc/min (25.2 lbs/hr) @ 2.0 Bar Green (2.0L) - 380 cc/min (36.1 lbs/hr) @ 2.0 Bar The theoretical mechanical limitations of most injectors to open/close are about 1.7ms from what I've read. So in your case PWs of 2.2ms are great and leave with you plenty of room to play. May I ask how you arrived at 2.2ms? Looking at my datalogs I see that at idle my PWs are 1.3-1.4ms, I never really analyzed this but this is a problem since the injectors are limited to 1.7ms. Correct? Should I change # of squirts to 2 instead of 4 (double req calc req fuel from 4.2 to 8.4ms) will yield PW of 1.77ms. The equation is PW = REQ_FUEL * VE * MAP * E + accel + Injector_open_time If I do the calcs manually I should get 4.2ms * 30% x (29 / 100 kpa) + 1.0ms = 1.36ms which is what i see in my datalogs. In addition, with the Green 2.0L injectors my max situations are as follows: WOT @ 5000-5500 rpm, PW ~4.2ms, Duty cycle 39%, AFR is really rich at around 11.6. I can send my datalog for anyone that is interested. This just illustrates that these injectors are WAY oversized as previously mentioned. I'm looking at this Injector flow table trying to figure out which injectors I want to go with: http://users.erols.com/srweiss/tableifc.htm I want to go with high impedence so I can move away from PWM. Any suggestions? I found some more info on your Ford Probe injectors here: http://www.fuelinjector.citymaker.com/page/page/5129028.htm 1993-97 application. Here is a set on ebay. Too $$ though. I'd rather buy a used set and send them off to cruzin performance. I'll keep an eye out for ~21-22lb injectors cross referenced between This site for flow data and This site for application then check ebay periodically. Any tips would be most appreciated, also I haven't looked at MS fuel requirements and PW in over a year so i might be a little rusty. Thanks@ Attached image(s)
toon1 FI retrofit May 17 2007, 07:31 PM
toon1 more May 17 2007, 07:32 PM
toon1 one more May 17 2007, 07:33 PM
jimkelly toon1 you are the man - keep us posted as to perfo... May 17 2007, 08:07 PM
BMXerror Who did the machining? Looks good.
Mark D. May 17 2007, 08:28 PM
toon1 Thank's, I did all the machining, I'm not ... May 17 2007, 08:38 PM
yarin Great stuff! Thanks for posting pics!
I... May 19 2007, 09:41 PM
toon1
I... May 20 2007, 01:16 AM
swl I really like the manifold you built. I know we d... May 20 2007, 06:07 AM
toon1
I really like the manifold you built. I know we ... May 20 2007, 09:42 AM
swl
If you could design a cheap, and easy way to us... May 20 2007, 12:47 PM
brer :clap: I'm impressed.
Keep us posted on yo... May 20 2007, 09:11 PM
Mueller nice job.....
for "brand" new Ford (and... May 21 2007, 03:46 AM
yarin
nice job.....
for "brand" new Ford (an... May 21 2007, 07:14 AM
greybeard50 This is exactly what I was contemplating for my T4... May 21 2007, 07:57 AM
MecGen Hey Thumbs Up ! :clap:
Thanx for saving a l... May 21 2007, 08:03 AM
type11969 5.slow injectors work too and can be readily found... May 21 2007, 08:24 AM
Dominic Nice work! :beer2:
I'm interested to... May 21 2007, 08:53 AM
toon1
This is exactly what I was contemplating for my T... May 21 2007, 10:28 AM
yarin Hey Keith,
Sorry to dig up this old thread, but I... Nov 24 2007, 12:03 AM
Carrera916 Hey Toon,
it looks real good and i'm doing th... Nov 24 2007, 12:36 AM
toon1
Hey Toon,
it looks real good and i'm doing t... Nov 24 2007, 12:56 AM
Carrera916 Yeah, your set up sounds good and yes, my AAR will... Nov 24 2007, 01:59 AM
toon1 If you are looking to keep things looking stock, D... Nov 24 2007, 09:12 AM
yarin I merged two databases of info to help others sele... Nov 24 2007, 02:04 PM
orange914 really impressive keith :trophy:
when your at the... Nov 24 2007, 03:40 PM
Jake Raby I have found that injectors operating over 80% dut... Nov 25 2007, 11:05 AM
jimkelly http://www.914world.com/bbs2/index.php?sho...c=772... Nov 25 2007, 11:42 AM
toon1 Hi guy's, I will try to catchup, I've been... Nov 25 2007, 07:48 PM
arvcube great info! i'm interested in how you... Nov 25 2007, 08:21 PM
toon1
great info! i'm interested in how you... Nov 25 2007, 08:37 PM
arvcube
The EDIS wheel is already...
Jake will have a... Nov 25 2007, 11:12 PM
toon1
Jake will have ... Nov 26 2007, 09:12 AM
Jake Raby
I don't like experimental things, unless thos... Nov 26 2007, 10:55 AM
toon1
I don't like experimental things, unless tho... Nov 26 2007, 11:07 AM
Jake Raby The main advantage of SDS was it is proven, well p... Nov 26 2007, 11:17 AM
toon1 what type of sensors does it have. Are they specif... Nov 26 2007, 11:56 AM
Jake Raby Yes, they are all GM excet the CHT which is Bosch.... Nov 26 2007, 01:48 PM
toon1 Good info.are you going 13:1 accross the board.
... Nov 26 2007, 04:57 PM
Jeff Bowlsby I thought Dave Hunts problems mostly related to MS... Nov 26 2007, 09:14 PM
toon1 With the ignition system that the 914 provides, I ... Nov 26 2007, 11:09 PM
p914 I tried using high impedence injectors from a 89 v... Nov 26 2007, 11:29 PM
Jake Raby Were you using the low impedence resistor pack wit... Nov 27 2007, 12:09 AM
p914
Were you using the low impedence resistor pack wi... Nov 27 2007, 11:33 AM
toon1
I tried using high impedence injectors from a 89 ... Nov 27 2007, 11:33 AM
ottox914
SDS is to be commended for providing a basic harn... Nov 27 2007, 11:16 PM
Jake Raby I have never had an SDS harness issue either.. The... Nov 28 2007, 06:19 AM
DNHunt Ah yes, I remember that beast.
Dave Nov 28 2007, 07:38 AM
JmuRiz From looking at Jake and David Parsons' projec... Nov 28 2007, 12:34 PM
ottox914 Its not that hard, read things over 100 times, kno... Nov 28 2007, 01:16 PM
Jake Raby Looks like an EFI workshop is in order, or perhaps... Nov 28 2007, 01:33 PM
blitZ
Looks like an EFI workshop is in order, or perhap... Nov 29 2007, 07:34 AM
ottox914 Whats out of focus for you? Nov 29 2007, 09:06 AM
Jake Raby This sytatement from SDS' web page is perfect.... Nov 29 2007, 09:11 AM
ottox914
Its not that hard, read things over 100 times, kn... Nov 29 2007, 12:30 PM
Ray Warren
Its not that hard, read things over 100 times, k... Nov 29 2007, 04:15 PM
blitZ I know my current Djet injectors are triggered by ... Nov 29 2007, 01:05 PM
Jake Raby SDS uses signal from the negative side of the coil... Nov 29 2007, 03:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd October 2026 - 09:54 PM |
