JWest Shift Kit Install Part 2, the forward shift rod |
McMark |
Jun 11 2007, 01:45 AM
Click here for part 1.
Time to install the forward shift rod section. This is the section that goes inside the car. There is a bit of welding. But this was a pretty easy install. First we cut the stock forward shift rod just behind the welds. We will be keeping the section on the left which is what attaches to the shifter. We will need to remove the remnants of the outer tube and just keep the insert. To remove the outer section, we used a lathe because one was available. You can also carefully grind off the welds, which would be just as easy. James gives a measurement for the total length of the shift rod (34 3/4" IIRC?). So this is what it will look like. I measured the rod and marked where it needed to be. The mark let me easily see if something got bumped out of place just before welding. The bushing is pretty easy to install. We just held the bushing in place, marked where to drill and made some holes. A quick paint and then bolt up the bushing (there is a specific way to orient the bushing). This was an early chassis which doesn't have the circle on the firewall (it's got a big oval). So we ground that all off and used an extra piece of rubber behind the bushing to completely seal it to the body. And finally, I hopped in the car with an extendable magnet and used that to feed the bolts through the holes. Then Andy grabbed them from the engine bay so I could detach the magnet. It worked great. Then I used a long 1/4" extension to hold the bolts in place while Andy slipped the bushing over the bolts and threaded on the nuts. Here is the shift rod TIG welded together. A quick coat of paint to protect it and then we slid it into place. We attached the new rod to the shifter so that when you pull back as far as it will go, the shift rod just sticks out past the bushing. Then we put the univeral joint onto the end. There is one more part to go. The rear shift rod section! (IMG:style_emoticons/default/wink.gif) Stay tuned later this week. |
Jeff Hail |
Nov 24 2007, 10:15 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Lo-Fi Version | Time is now: 24th November 2024 - 08:06 PM |
