toon1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 ![]() |
I've been working on retrofitting newer fuel injectors for the 914. My goal was to find an injector that can utilize as many of the stock parts as possible.
I came up with a inj. off a 96 forn escort 1.8l motor. One comment is needed, this will only work with an aftermarket FI system s these inj. are HIGH inpedence. This setup gives the ability to use higher fuel pressure, 44psi . It has a lower flow rate than the stock inj.. so the pulse widths will be longer and should give a little better idle quality. these are disc style rather than pintle( stock). fuel atomization will be much better giving a cleaner, more efficiant burn. The length of the inj. where shorter than stock so I added an O ring to make up the difference. The plastic tips are different ,I cut them off and put the tip of the stock inj. on the new inj., fit perfect. now the stock tip O ring can be used. the fuel rail was machined to tolerance for the top O ring seal. And I made a bracket to support the fuel rail from vibration and also keeping it from popping off the top of the inj. Here's the setup assembled. enjoy Attached image(s) ![]() ![]() |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
I have found that injectors operating over 80% duty have seriously diminished lives, some lasting only a few thousand miles. I do prefer a tad higher FP and duty cycle using smaller injectors to really boost down low performance and drivability, but their are downfalls to this.
You'll more than likely see that the calculations are just that as you start tuning. Cam, heads, air density and exhaust system effectiveness all impact the tuning of the system. Don't be disappointed if all the calculations and math get you no where. I just went through this as I completed development of the Pinzgauer EFI system last month when things didn't go as calculated at all.... Good luck with MS, I have nothing good to say about it at this point after it cost me 5 years of greif with Dave Hunt's builds and consistent failure. |
Lo-Fi Version | Time is now: 26th April 2025 - 02:22 AM |
