Crush Washer Question, For the oil temp sender... |
jim_hoyland |
Nov 26 2007, 09:08 PM
Get that VIN ? Group: Members Posts: 9,467 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Changed my oil temp sender and noticed the crush washer is pretty flat. Had to tighten the sender pretty good to almost-stop an oil leak.
Does the crush washer need replacement after boing used once or twice ? Any easy sources for these from flaps ? |
Pat Garvey |
Nov 26 2007, 09:15 PM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
Changed my oil temp sender and noticed the crush washer is pretty flat. Had to tighten the sender pretty good to almost-stop an oil leak. Does the crush washer need replacement after boing used once or twice ? Any easy sources for these from flaps ? It's like the crush washer on the oil drain plug, or the screen plate - good for one use only, or they will either leak or cause you to over-torque (niether of which is good). Should be able to find them at any VW dealer...or there's always Uncle George. |
Lo-Fi Version | Time is now: 31st October 2024 - 07:30 PM |
