Noisy valves?, 2.0 |
Bogaat |
Nov 17 2007, 10:37 AM
Member Group: Members Posts: 195 Joined: 8-January 07 From: Charleston, SC Member No.: 7,436 |
I just adjusted my valves after breakin using the captains instructions. Only two had to be adjusted as they were tight. I haven't really listened to the engine idle too much and am paranoid that the valves are loose. When I put my head down low next to the engine, I hear the valves doing their thing. I am not too familair with the sounds these things are supposed to make as I am just getting this thing going. It sounds like there are a couple guys with small hammers down there making music. Sound right? If not, how long should I let these guys cool down before I check adjustment again? I typically wait overnight on my bug, but I would like to do this later today. 6 hours? Thanks guys (IMG:style_emoticons/default/beer3.gif)
rjames |
Nov 17 2007, 03:29 PM
I'm made of metal Group: Members Posts: 4,132 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
QUOTE Exhaust leaks at the head can sound like loud tappets also. I thought my engine was on it's way out because of how noisy it was. It turned out to be an exaust leak. Check your exhaust stud nuts/bolts while your under there. |
Bogaat |
Nov 27 2007, 10:09 AM
QUOTE Exhaust leaks at the head can sound like loud tappets also. I thought my engine was on it's way out because of how noisy it was. It turned out to be an exaust leak. Check your exhaust stud nuts/bolts while your under there. That was it. Those things loosened up pretty good after the break in! Much better now (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 31st October 2024 - 07:26 PM |
