All the cool kids are doing it..., Low budget progress thread (Slow Race prep.) |
BMXerror |
Sep 17 2007, 09:42 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Well, with all the work that I'm doing to my car lately, I might as well start my own progress thread.
Backstory I bought 4702912742 from my pops about a year and a half ago for $600 dollars, but it wasn't a steal. It had been sitting for about five years and needed a lot of work. He A couple years later he had been looking for a teener for a little while and picked this one up cheap at a dealership in Pomona Ca. He drove it for a while, but it had tons of problems, and soon he decided to sell it. However, the person who test drove it blew first gear, and out to the back yard it was sent. Fast forward five years to when I was financially ready to get a car to start racing. Long story short, after deciding that I wanted the 914 instead of an older Miata, I told him I was interested. He said that if I bought him a set of mufflers for his bike, we'd call it even. After that I spent about another 4K just getting it drivable. I replace all four rotors, rebuilt all four calipers, replace the brake lines with braided steel, replaced the hard lines that I broke, replaced the master cylinder, resealed the motor (after my socket and extension locked the motor up), bought two trannies for it (the first one was no good), put a new clutch and pilot bearing in it, put new rubber on the ground (Khumos), fixed and lubed all kinds of latches and hinges to be able to get into all the various compartments, replaced most of the vacuum lines and fuel lines.... the list goes on. These were all just stock replacements to get it running well. I further had to fight with the injection system for a few months until I figured out that I had it hooked up wrong. (IMG:style_emoticons/default/headbang.gif) Of course, this is the very abbreviated version of the story. As anyone with one of these things knows, the words it takes to describe what parts you changed don't even come close to showing the blood, sweat, and yes, sometimes tears that you put into your work. But anyways, it is running decent now (the motor is still a little tired) so it's time to do some improvements. After all, racing is what I bought the thing for. So I'll try to bring anyone who cares up to date on some of the things I've been working on. Mark D. |
BMXerror |
Dec 5 2007, 02:06 PM
I've also been working on getting some gauges installed. The car originally had nothing but a tach, speedometer and fuel gauge.... well, and an oil pressure light. I bought a CHT, oil pressure, and oil temperature gauge from E-gauges.com, and have been gradually getting them wired up. It's not like I'm risking anything by taking my time as the car isn't even running right now. Anyways, the first thing I had to do was run some loom material under the front section of the tunnel. I actually did this a while ago when the PO's shitty wiring (under the trim piece on the longs) decided to short itself on a screw and melt the carpet.
I ran a fisher through the path that I wanted the loom material to go, while pulling a string along behind it (from back to front). I then poked a couple holes through the material, tied the string through those holes, and greased up the piece I was pulling through. It actually came through pretty easily. I then sent the fisher down the loom material and pulled a string through. The string is double the length of the loom piece with a washer on both ends, and it just stays in there so it's easy to pull wires when I need to. Simple pic. Note that this is before I got the interior repainted. As you can see, I split the loom material where it comes up for air between the seats for accessibility. The back section was done with a hole saw and some rubber grommets from NAPA. I strung it up the same way to help me fish wire. Through the firewall:... Mark D. |
Lo-Fi Version | Time is now: 28th June 2024 - 12:50 PM |
