SteveL |
Senior Member ![]() ![]() ![]() Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None ![]() ![]() |
Mom drives a 1997 Saturn SL1.
Last winter it had great heat. Once Warned up, temp guage was solid at 1/2. Over the summer, the radiator died. Replaced with brand new. I also replaced the thermostat with a standard replacement. Now, the temp guage only barely gets to 3/8, and it isn't hot enough to make good heat here in MN. Help Please? |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,512 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Check the coolant level. Coolant could be low and not able to circulate through the heater core. Also I think if the T stat fails it fails in the open position. This would prevent the engine from warming properly.
Lo-Fi Version | Time is now: 26th June 2024 - 11:15 AM |
