All the cool kids are doing it..., Low budget progress thread (Slow Race prep.) |
BMXerror |
Sep 17 2007, 09:42 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Well, with all the work that I'm doing to my car lately, I might as well start my own progress thread.
Backstory I bought 4702912742 from my pops about a year and a half ago for $600 dollars, but it wasn't a steal. It had been sitting for about five years and needed a lot of work. He A couple years later he had been looking for a teener for a little while and picked this one up cheap at a dealership in Pomona Ca. He drove it for a while, but it had tons of problems, and soon he decided to sell it. However, the person who test drove it blew first gear, and out to the back yard it was sent. Fast forward five years to when I was financially ready to get a car to start racing. Long story short, after deciding that I wanted the 914 instead of an older Miata, I told him I was interested. He said that if I bought him a set of mufflers for his bike, we'd call it even. After that I spent about another 4K just getting it drivable. I replace all four rotors, rebuilt all four calipers, replace the brake lines with braided steel, replaced the hard lines that I broke, replaced the master cylinder, resealed the motor (after my socket and extension locked the motor up), bought two trannies for it (the first one was no good), put a new clutch and pilot bearing in it, put new rubber on the ground (Khumos), fixed and lubed all kinds of latches and hinges to be able to get into all the various compartments, replaced most of the vacuum lines and fuel lines.... the list goes on. These were all just stock replacements to get it running well. I further had to fight with the injection system for a few months until I figured out that I had it hooked up wrong. (IMG:style_emoticons/default/headbang.gif) Of course, this is the very abbreviated version of the story. As anyone with one of these things knows, the words it takes to describe what parts you changed don't even come close to showing the blood, sweat, and yes, sometimes tears that you put into your work. But anyways, it is running decent now (the motor is still a little tired) so it's time to do some improvements. After all, racing is what I bought the thing for. So I'll try to bring anyone who cares up to date on some of the things I've been working on. Mark D. |
J P Stein |
Dec 7 2007, 06:57 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Depending on who/what/where group you're going to run with, you may have a problem with your seat/harness set up. For PCA DEs, it's illegal. Some regions (most, I would think) are also going to enforce the new rule for AX.
In a nutshell: Your harnesses must run thru slots in the seats (at the shoulders & sub belts). RTRB. |
okieflyr |
Dec 7 2007, 08:45 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
JP,
What if he were to weld up some "hoops" on top of the bar for the belts to go thru? It seems that would provide the desired belt location and stability.(?) I'm not familiar with their rules though....... Depending on who/what/where group you're going to run with, you may have a problem with your seat/harness set up. For PCA DEs, it's illegal. Some regions (most, I would think) are also going to enforce the new rule for AX. In a nutshell: Your harnesses must run thru slots in the seats (at the shoulders & sub belts). RTRB. |
J P Stein |
Dec 8 2007, 09:35 AM
JP, What if he were to weld up some "hoops" on top of the bar for the belts to go thru? It seems that would provide the desired belt location and stability.(?) I'm not familiar with their rules though....... Depending on who/what/where group you're going to run with, you may have a problem with your seat/harness set up. For PCA DEs, it's illegal. Some regions (most, I would think) are also going to enforce the new rule for AX. In a nutshell: Your harnesses must run thru slots in the seats (at the shoulders & sub belts). RTRB. In my experience whenever you go beyond the letter of the rule book, you cast your fate to the wind...or who ever is teching the car. If you spend time/effort trying to work around the "letter", you will probably be disappointed. This particular issue is PCA liability insurance generated. As a past PCA AX chair, were it my decision, you wouldn't run in the event. No reason to put the region in jeopardy for one guy should something go wrong. WAG.... any event chair is gonna feel the same. Your best bet is to find a used race seat....2 if you want a passenger. Look for a used Kirkey seat. They are used by lots of circle track guys and can be had cheep....not very comfortable on the street tho. |
Lo-Fi Version | Time is now: 25th June 2024 - 06:19 PM |
