porschecb |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,092 Joined: 13-August 04 From: Las Vegas NV Member No.: 2,529 Region Association: None ![]() |
Got to get rid of the oil soaked carpets! Looking at COSTO.COM interlocking floor panels $2.06 per square! Your thoughts?
Michael (IMG:style_emoticons/default/pray.gif) |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
Those all look nice for a car storage garage, I have a hard time believing that ANY of those would survive in my garages. With the welding, plasma cutting, grinding, cutting sparks, they would be bad looking in no time.
I don't think the coating or plastic tile exist that would stand up to molten steel or tiny fireballs as they drop on the floor. Most factories that I visit that do heavy welding/fabrication of any sort leave bare concrete or use a simple sealer that is re-applied every so often. I mainly try to keep any vehicle parked in my garages leak free. Then I don't have to worry about the oil stains that don't want to come out. When there is a spill, it is cleaned up right away. If you are trying for something durable to park cars on and do light work, I would recommend a heavy duty (multi-layer epoxy based) coating that is professionally applied. This way you have some sort of warranty against a lifting/peeling problem. Good luck. |
Lo-Fi Version | Time is now: 26th June 2024 - 08:22 AM |
