More 1.7 D-Jet issues, Please help before I remove it!! |
BK911 |
Dec 7 2007, 07:18 AM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
One reason I bought this car was because it still had the fuel injection. But now I am getting so frustrated trying to get it to run well, I am considering swapping the FI for carbs. Please help before I switch to carbs!
She runs well cold and hot, but not in-between. She will stall and is very difficult to restart. In fact, I have pushed her out of traffic on several occasions after she stalled at a red light. I wait a couple of minutes and she fires right back up. I have a gunson and have set the CO to 2.5 at idle and 2500 rpm. And again, she runs well once hot. The AAR works. I swapped out the CHT even though the old one tested fine. I am thinking it’s the cold start valve. I disconnected the wire to the CSV last night and reset the CO to 2.5. I went for a ride, came home and shut off the car. Let the gunson calibrate then rechecked the CO. Very lean and wouldn’t run worth a crap. I am thinking I have a leaky CSV. It was leaking when I set the CO and stopped leaking when the car heated up? Can I remove it? How do you plug it? If I just remove the gas lines to it, will it leak air? Is 2.5 a good number for the CO at idle and 2500 rpm? I’d appreciate any help. Please help me keep this car original!! |
brp986s |
Dec 8 2007, 06:32 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
engine vacuum, warm @ idle = ?
fuel pressure at various speeds = ? ign timing - correct advance ? Steady, or jumping all around? fwiw, mine just started acting up today. have to keep it at 2000rpm at stop lights or it'll stall. Yay. Nice of it to wait until the coldest day of the year for it to happen. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:48 PM |
