BK911 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None ![]() |
One reason I bought this car was because it still had the fuel injection. But now I am getting so frustrated trying to get it to run well, I am considering swapping the FI for carbs. Please help before I switch to carbs!
She runs well cold and hot, but not in-between. She will stall and is very difficult to restart. In fact, I have pushed her out of traffic on several occasions after she stalled at a red light. I wait a couple of minutes and she fires right back up. I have a gunson and have set the CO to 2.5 at idle and 2500 rpm. And again, she runs well once hot. The AAR works. I swapped out the CHT even though the old one tested fine. I am thinking it’s the cold start valve. I disconnected the wire to the CSV last night and reset the CO to 2.5. I went for a ride, came home and shut off the car. Let the gunson calibrate then rechecked the CO. Very lean and wouldn’t run worth a crap. I am thinking I have a leaky CSV. It was leaking when I set the CO and stopped leaking when the car heated up? Can I remove it? How do you plug it? If I just remove the gas lines to it, will it leak air? Is 2.5 a good number for the CO at idle and 2500 rpm? I’d appreciate any help. Please help me keep this car original!! |
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
if it is truely only a mid-range temp related problem - it has got to be the TS1 or head temp sensor giving the ecu and bad reading?
what color are your fuel injectors - they should be yellow for 1.7. does it really run fine after it is warmed up?? jim |
Lo-Fi Version | Time is now: 25th June 2024 - 08:34 PM |
