OT: Roof framing, alteration |
thomasotten |
Dec 10 2007, 02:06 PM
Senior Member Group: Members Posts: 1,553 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
I have an existing roof on my house that is pitched and creates a cathedral type ceiling underneath. I am considering increasing the pitch of this roof, for ascthetic reasons mostly, but also to add insulation to the roof, which I don't thick is adequetly insulated. There is no attic space right now, so I cant' be sure of the insulation, although it gets hot in summer time. I want the final roof to be 12/12, and to do this, I would need to raise the ridge by about 2'. From the ridge, I would then run rafters down to the bottom of the roof fascia. Instead of raising each rafter up and causing a mess, I am considering building a structure over the exsiting roof, and then sheathing over. That way I don't disturb the ceiling. I was thinking of also doing this in phases, keeping the existing shingles on as a I go. What do you think?
jasons |
Dec 10 2007, 02:19 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
So, you want to leave your existing roof intact and build a new roof on top. Then, use the new dead space between the 2 for insulation?
I think, the first question needs to be, how are you going to carry the load of the new roof structure and, can your existing roof/walls support their share of that load? |
Lo-Fi Version | Time is now: 27th September 2024 - 09:38 AM |
