Danny_Ocean |
Member ![]() ![]() Group: Members Posts: 170 Joined: 27-June 07 From: Fort Lauderdale, FL Member No.: 7,846 Region Association: South East States ![]() |
Title pretty much says it all. I need to test my fuel tank fittings with the tank removed and don't want to keep adding/draining gasoline (discovered leak after 1st install... (IMG:style_emoticons/default/headbang.gif) ). Can anyone recommend a liquid which I can substitute for testing? Tank will be completely drained/dried before re-installation.
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Water is about the safest thing to use. I've used it before and works great. Dry it out good and it'll be fine.
Cheers, Elliot |
Danny_Ocean |
Water is about the safest thing to use. I've used it before and works great. Dry it out good and it'll be fine. Cheers, Elliot My only concern is viscosity. Water is "thicker" than gas and may not show all leaks... I'm thinking alcohol or something "thin". |
Lo-Fi Version | Time is now: 26th June 2024 - 11:06 AM |
