Danny_Ocean |
Member ![]() ![]() Group: Members Posts: 170 Joined: 27-June 07 From: Fort Lauderdale, FL Member No.: 7,846 Region Association: South East States ![]() |
Title pretty much says it all. I need to test my fuel tank fittings with the tank removed and don't want to keep adding/draining gasoline (discovered leak after 1st install... (IMG:style_emoticons/default/headbang.gif) ). Can anyone recommend a liquid which I can substitute for testing? Tank will be completely drained/dried before re-installation.
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
what are you going to do with 15 gallons or so of flamable liquids? water, cap the supply, return lines, and the vent at the top, then presurize the tank at the top with your compressor. low psi will do the trick.
k |
911quest |
Member ![]() ![]() Group: Members Posts: 277 Joined: 26-March 06 From: Louisville Ky Member No.: 5,773 Region Association: South East States ![]() |
what are you going to do with 15 gallons or so of flamable liquids? water, cap the supply, return lines, and the vent at the top, then presurize the tank at the top with your compressor. low psi will do the trick. k You don't even need to use water just use air pressure and pressurize the tank to make sure it hold pressure. If you must use a solvent I would use saftey-kleen or what ever you use in your parts washer so you can recycle it. |
Lo-Fi Version | Time is now: 26th June 2024 - 10:58 AM |
