> Substitute liquid for testing fuel tank?
Danny_Ocean
post Dec 10 2007, 09:48 PM
Title pretty much says it all. I need to test my fuel tank fittings with the tank removed and don't want to keep adding/draining gasoline (discovered leak after 1st install... (IMG:style_emoticons/default/headbang.gif) ). Can anyone recommend a liquid which I can substitute for testing? Tank will be completely drained/dried before re-installation.
Matt Meyer
post Dec 11 2007, 02:01 PM
Überlurker
How about just compressed air. LOW PRESSURE would tell if you have a good seal. Finding the leak might be a little difficult if you dont have a big tank attached.
Danny_Ocean
post Dec 11 2007, 04:24 PM
QUOTE(Matt Meyer @ Dec 11 2007, 03:01 PM) *
I know where it's leaking from (feed & return tubes). Just need to know if I've repaired the leak before re-installing for the second time.. (IMG:style_emoticons/default/mad.gif)
Danny_Ocean   Substitute liquid for testing fuel tank?   Dec 10 2007, 09:48 PM
Headrage   Water? :confused:   Dec 10 2007, 09:56 PM
Danny_Ocean   Water? :confused: Yeah, that was my first thoug...   Dec 10 2007, 10:03 PM
boxstr   14 year old single malt scotch. CCL   Dec 10 2007, 10:15 PM
Danny_Ocean   14 year old single malt scotch. CCL Hmmm....tha...   Dec 10 2007, 10:31 PM
GWN7   methonal You can buy it at most FLAPS..........w...   Dec 10 2007, 10:57 PM
Danny_Ocean   methonal You can buy it at most FLAPS....... I...   Dec 10 2007, 11:13 PM
Elliot Cannon   Water is about the safest thing to use. I've ...   Dec 10 2007, 11:13 PM
Danny_Ocean   Water is about the safest thing to use. I've...   Dec 10 2007, 11:15 PM
boxstr   Friendly Local Auto Parts Store: FLAPS CCL   Dec 10 2007, 11:20 PM
jimtab   Methanol=denatured alcohol...at your local hardwar...   Dec 11 2007, 12:05 AM
ConeDodger   Methanol=denatured alcohol...at your local hardwa...   Dec 11 2007, 12:13 AM
rhodyguy   what are you going to do with 15 gallons or so of ...   Dec 11 2007, 12:04 PM
911quest   what are you going to do with 15 gallons or so of...   Dec 11 2007, 02:06 PM
Matt Meyer   How about just compressed air. LOW PRESSURE would...   Dec 11 2007, 02:01 PM
Danny_Ocean   How about just compressed air. LOW PRESSURE woul...   Dec 11 2007, 04:24 PM
messix   use water, then drain tank of water when testing i...   Dec 11 2007, 02:56 PM
rjames   :agree: Plus water in the tank just leads to a...   Dec 11 2007, 04:26 PM
GWN7   methonal is sold in most Northern climates as ...   Dec 11 2007, 11:16 PM
- Lo-Fi Version Time is now: 6th January 2025 - 07:33 PM
