Danny_Ocean |
Member ![]() ![]() Group: Members Posts: 170 Joined: 27-June 07 From: Fort Lauderdale, FL Member No.: 7,846 Region Association: South East States ![]() |
Title pretty much says it all. I need to test my fuel tank fittings with the tank removed and don't want to keep adding/draining gasoline (discovered leak after 1st install... (IMG:style_emoticons/default/headbang.gif) ). Can anyone recommend a liquid which I can substitute for testing? Tank will be completely drained/dried before re-installation.
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 3,996 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
QUOTE You don't even need to use water just use air pressure and pressurize the tank to make sure it hold pressure. If you must use a solvent I would use saftey-kleen or what ever you use in your parts washer so you can recycle it. (IMG:style_emoticons/default/agree.gif) Plus water in the tank just leads to a rusty tank. |
Lo-Fi Version | Time is now: 26th June 2024 - 11:03 AM |
