Rear rotor hold-down screws, ....are they necessary? (five lug conversion question) |
jaybird840 |
Dec 12 2007, 02:45 PM
Member Group: Members Posts: 163 Joined: 27-September 06 From: Austin, TX Member No.: 6,927 Region Association: Southwest Region |
I just bolted up my new Eric Shea control arms with the Elephant poly bronze bushings for my five lug rear conversion and I'm really psyched. They installed almost effortlessly, and I'm completing the install. However, when I went to install the new 914/6 rear rotors (thanks Mark H!) the holes for the two little screws that hold the rotor to the hub no longer line up. What are my options? 1) drill and tap for the new location 2) can you let the rotor "float" and just keep it held down with the torque of the lug nutz? Thanks guys!!!
--Jaybird |
Jeffs9146 |
Dec 12 2007, 08:55 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
QUOTE should I run down to my FLAPS and purchase one of those brake-caliper-mashy-openy tools? A C-clamp with an old brake pad will work, just take it slow (small adjustments at a time) you could have a rusted piston cylinder end and cause damage. You need to turn the screw as you adjust the clamp. |
Lo-Fi Version | Time is now: 6th January 2025 - 08:10 PM |
