> Rear rotor hold-down screws, ....are they necessary? (five lug conversion question)
jaybird840
post Dec 12 2007, 02:45 PM
I just bolted up my new Eric Shea control arms with the Elephant poly bronze bushings for my five lug rear conversion and I'm really psyched. They installed almost effortlessly, and I'm completing the install. However, when I went to install the new 914/6 rear rotors (thanks Mark H!) the holes for the two little screws that hold the rotor to the hub no longer line up. What are my options? 1) drill and tap for the new location 2) can you let the rotor "float" and just keep it held down with the torque of the lug nutz? Thanks guys!!!
--Jaybird
Eric_Shea
post Dec 12 2007, 09:59 PM
PMB Performance
Thats what the old brake pad is for!
Other side... difficult to keep the c-clamp on the other side as the face of the caliper there is uneven. The old brake pad or even the piston itself is obviously flat and hence not the problem area.
This is the outer piston as well. The adjuster is smack dab in the middle of where the c-clamp would hold best. If it were the inner piston, which is gear driven it wouldn't be an issue as the adjuster hole is below center.
I've never had to use a clamp to adjust a 914 caliper and I would venture to say, if you've had to do this a few times, it's best to step back and fix the actual problem...
I just said it would be difficult... worth a try and it might even work but, that's not what his problem is. (IMG:style_emoticons/default/wink.gif)
jaybird840   Rear rotor hold-down screws   Dec 12 2007, 02:45 PM
Spoke   I don't believe you need the little screws. Th...   Dec 12 2007, 03:01 PM
SLITS   On a /4 the screws keep the rotor from falling off...   Dec 12 2007, 03:02 PM
Jeffs9146   I drilled mine but I was told I didn't need to...   Dec 12 2007, 03:41 PM
Eric_Shea   914 and 911 (hence 914-6) hold down screws are in ...   Dec 12 2007, 04:13 PM
rfuerst911sc   Funny you posted this because I'm in the same ...   Dec 12 2007, 04:33 PM
jaybird840   Funny you posted this because I'm in the same...   Dec 12 2007, 04:40 PM
rfuerst911sc   Funny you posted this because I'm in the sam...   Dec 13 2007, 04:59 AM
Jeffs9146   You need to loosen the pad adjuster on the outsi...   Dec 12 2007, 05:23 PM
Eric_Shea   If you decide to tap, tap both. It's best t...   Dec 12 2007, 05:24 PM
Eric_Shea   Agreed, it would be fairly easy at machining tim...   Dec 12 2007, 06:19 PM
Jeffs9146   Was the hub powder coated on the face between the ...   Dec 12 2007, 06:30 PM
Eric_Shea   No. Why would that matter though...? :confused:   Dec 12 2007, 06:31 PM
Jeffs9146   It would move the rotor outward by .006 - .008 whi...   Dec 12 2007, 06:44 PM
Cap'n Krusty   To emphasize what was mentioned earlier, ALWAYS ap...   Dec 12 2007, 07:15 PM
jaybird840   To emphasize what was mentioned earlier, ALWAYS a...   Dec 12 2007, 08:31 PM
Jeffs9146   A C-clamp with an old brake pad will work, just ...   Dec 12 2007, 08:55 PM
Eric_Shea   Nada. The width of a business card isn't go...   Dec 12 2007, 09:01 PM
Eric_Shea   Here's one that was on the bench. The assembl...   Dec 12 2007, 09:10 PM
Jeffs9146   Thats what the old brake pad is for! :idea: ...   Dec 12 2007, 09:28 PM
Eric_Shea   Other side... difficult to keep the c-clamp on t...   Dec 12 2007, 09:59 PM
Jeffs9146   I agree! The alternative is to rebuild! ...   Dec 12 2007, 10:35 PM
- Lo-Fi Version Time is now: 17th September 2026 - 04:42 AM
