> OT: Roof framing, alteration
thomasotten
post Dec 10 2007, 02:06 PM
I have an existing roof on my house that is pitched and creates a cathedral type ceiling underneath. I am considering increasing the pitch of this roof, for ascthetic reasons mostly, but also to add insulation to the roof, which I don't thick is adequetly insulated. There is no attic space right now, so I cant' be sure of the insulation, although it gets hot in summer time. I want the final roof to be 12/12, and to do this, I would need to raise the ridge by about 2'. From the ridge, I would then run rafters down to the bottom of the roof fascia. Instead of raising each rafter up and causing a mess, I am considering building a structure over the exsiting roof, and then sheathing over. That way I don't disturb the ceiling. I was thinking of also doing this in phases, keeping the existing shingles on as a I go. What do you think?
jd74914
post Dec 12 2007, 09:51 AM
Its alive
Typically you need to get plans and then submit for the building permit. At least around here it doesn't matter who does the actual construction as long as they stick to the plans. You will probably need to have it inspected afterwards to get your certificate of occupancy, but thats probably more up to your locality.
rick 918-S
post Dec 12 2007, 10:59 PM
Hey nice rack! -Celette
QUOTE(jd74914 @ Dec 12 2007, 07:51 AM) *
(IMG:style_emoticons/default/agree.gif) Everyplace is different so check with your local inspector. Most places now require a design plan based on the building codes. This would show current construction and purposed changes with inspections based on what your area requires.
thomasotten   OT: Roof framing, alteration   Dec 10 2007, 02:06 PM
jasons   So, you want to leave your existing roof intact an...   Dec 10 2007, 02:19 PM
Jeff Bowlsby   A couple of things to consider: that amount of wo...   Dec 10 2007, 02:24 PM
jd74914   Don't do it; do it once and do it right. While...   Dec 10 2007, 03:55 PM
thomasotten   Well, I talked about it with a contractor friend. ...   Dec 11 2007, 08:25 AM
flippa   I'm sure that this may be doable and has been ...   Dec 11 2007, 08:56 AM
rick 918-S   Better check local buillding codes. Around here th...   Dec 11 2007, 10:13 AM
brer   So its an open beam ceiling right? Very nice to ...   Dec 11 2007, 10:28 AM
rhodyguy   existing roof (3 tab, etc) tear off is an equal we...   Dec 11 2007, 12:20 PM
thomasotten   What is the typical procedure? I would have to su...   Dec 12 2007, 07:51 AM
jd74914   Typically you need to get plans and then submit fo...   Dec 12 2007, 09:51 AM
rick 918-S   Typically you need to get plans and then submit f...   Dec 12 2007, 10:59 PM
flippa   Thomas Do a search on your City regulations on li...   Dec 13 2007, 08:59 AM
r_towle   be careful to investigate the fire code. In MA, wh...   Dec 20 2007, 06:09 PM
banger   I had a similar situation. I have a cathedral cei...   Dec 20 2007, 06:37 PM
rhodyguy   if you go the the insulated panel route, ensure yo...   Dec 21 2007, 11:46 AM
thomasotten   This is my plan, by the way, notice that also, wit...   Dec 23 2007, 04:28 AM
Joe Ricard   This is not really off topic. This reflects what w...   Dec 23 2007, 06:55 AM
thomasotten   Well, it's mostly for asthetic reasons that I ...   Dec 23 2007, 10:33 AM
flippa   Are those 2x4’s that you are proposing for the n...   Dec 23 2007, 04:42 PM
banger   With the radiant barrier, it would be easier to bu...   Dec 23 2007, 04:54 PM
- Lo-Fi Version Time is now: 27th December 2024 - 06:48 AM
