orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
just wondering what t.b. conversions are out there and what issues have been incured?.
what size is the stock t.b. anyway |
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
Don't bore it out.
Think of it using this equation: m(dot)= p*A*V. (p is a constant, the density of air) The engine consumes a finite amount of air (M(dot)). This value is only dependent on engine speed. The air's speed is inversely dependent on the area of the TB/runners it flows through (A). When these have larger cross-sectional areas the air inside of them moves at a slower rate (V), which kills efficiency. Maximum power can be found with air speeds of around .4 or .5 mach usually. Once you go supersonic efficiency drops though. Basically you want high intake port air velocity for best performance. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 06:22 PM |
