Oil pressure waaaay too high ..., happened suddenly |
SirAndy |
Dec 17 2007, 10:46 PM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
this morning, i had to go to a meeting in SF and the car was running fine and all was good.
then, this evening i went to pick up my GF from work and when i started the car, the oil pressure went through the roof. i have the 0-5 gauge and normally the pressure at idle is about ~2 and under full load close to 5. now i'm getting 4-5 at idle and the needle hits the stop under load. (IMG:style_emoticons/default/WTF.gif) i checked on the oil cooler and thermostat, both work fine, supply and return line get hot/warm, so the oil is circulating in the lines. they engine sounds normal and i don't see any oil squirting out of the block anywhere. anyone know what could be wrong? (IMG:style_emoticons/default/confused24.gif) Andy PS: the motor is a '95 3.6L from a 993 ... |
Grngoat |
Dec 20 2007, 01:37 AM
Lurker Member Group: Members Posts: 158 Joined: 17-October 04 From: Fort Worth, TX Member No.: 2,967 Region Association: Southwest Region |
Just slightly off topic, but what sending unit are you using? I have a 5 bar gauge out of a 911 SC, but am still using the stock 993 sending unit which I understand to be calibrated for 10 bars. So the oil pressure reads double. Basically, the needle is pegged the instant the motor starts, so it acts more like an idiot light than a gauge. Have you fixed this somehow?
Lo-Fi Version | Time is now: 26th June 2024 - 01:55 AM |
