VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
So, at the Sterling meet I did a leakdown test on my motor, and found a problem with Cylinder 1. 45% leakdown, but 120 lbs of compression. Was tempted just to let sleeping dogs lie, but pulled the head off.
What was going on was clear as soon as we did that, the head was not totaly sealed to the cylinder, off by a very small amount. Instead of having the head recut, I decided to try and lap the two of them together. So, last night I hand lapped them, using ground graphite to check for even contact. I got good contact after the third round of hand lapping (lap, clean, check). Now I need to get the jug back on the block. I have a ring compressor on the piston, but I can't ficgure out how to get the head back on. Do I have to take the piston head off the rod? If so, how do I get it off. It looks like that tis a spring keeper that needs to be removed. Is there anyhting on the rod the needs to be loosened before I can pull the pin out to remove the piston head? Obviously, if there is a trick to getting the jug back on without pulling off the piston head, I'd like to do that. Zach |
type11969 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States ![]() |
Drop a straight edge across the cylinder tops too. Careful when tightening the socket on the head stud, you can crack a fin if you torque it down too much. I've used this method before but I question how accurate it is considering you cannot get the cylinders properly torqued to the case this way.
If a register is collapsed and a cylinder is sitting on an angle the case will have to be decked. You should be able to see this with a straight edge at the cylinder tops. I would measure the cylinder length with the cylinders off the engine with a set of calipers. If you compare side to side from the piston tops, you can be introducing error from different con rod lengths, piston pin heights, and differences in cyl to case torque. With the cylinders off you can also drop a straight edge across the cylinder registers check the registers again. -Chris |
Lo-Fi Version | Time is now: 25th June 2024 - 10:13 PM |
