thomasotten |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,550 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 ![]() |
I have an existing roof on my house that is pitched and creates a cathedral type ceiling underneath. I am considering increasing the pitch of this roof, for ascthetic reasons mostly, but also to add insulation to the roof, which I don't thick is adequetly insulated. There is no attic space right now, so I cant' be sure of the insulation, although it gets hot in summer time. I want the final roof to be 12/12, and to do this, I would need to raise the ridge by about 2'. From the ridge, I would then run rafters down to the bottom of the roof fascia. Instead of raising each rafter up and causing a mess, I am considering building a structure over the exsiting roof, and then sheathing over. That way I don't disturb the ceiling. I was thinking of also doing this in phases, keeping the existing shingles on as a I go. What do you think?
thomasotten |
Well, it's mostly for asthetic reasons that I want to do this. The ability to add radiant shielding insulation is just an added bonus. Plus, there is the porch area problem I mentioned, and the front siding under the gable needs addressing as well. Basically, my house needs a lot of work, and I figure I might as well make it the way I want it in the process.
Lo-Fi Version | Time is now: 26th June 2024 - 01:21 AM |
