> Spoke's 71 2.056L 914 Progress Thread, Driving it Like I Stole It
Spoke
post Dec 28 2007, 10:59 PM
Jerry
Like Zach said before, just what the World needs is another progress thread. So here it is for my 71 1.7L red ride.
I'm working on an engine swap for my leaky 1.7L with slipping clutch to a non-leaking, unknown GEX rebuilt 1.8L so I decided to concatenate several threads on this car into one progress thread.
Eventually I will sell the red 71 and keep the green 74 as my only 914. For now the plan is to get the new 1.8L engine in the car. The 1.8L has SSHE where the 1.7L in the car has very much corroded stock HE's.
Here's pics after last year's rear end accident that totaled the car and the finished product after many months of rehab.
Twystd1
post Dec 29 2007, 12:09 AM
You don't want to know... really.....
Is that a GEX tag on this engine...????????????
Clayton
Spoke
post Dec 29 2007, 03:33 AM
Jerry
QUOTE(Twystd1 @ Dec 29 2007, 01:09 AM) *
Yep. I tried contacting GEX to find out what work was done on the engine but since the guy I bought the engine from had bought it from someone else, GEX couldn't (or didn't want to) find the build sheet on the engine to see what work had been done. They needed the name of the owner at the time and the name of the 1st owner (assuming I'm the 3rd) didn't come up in their database.
I've had the engine running out of the car and it didn't leak oil and seemed to run fine given that I haven't loaded it down yet. It looks as if the case was opened as I could see some blue sealant on the inside of the oil breather opening. I assumed the blue sealant was not from the manufacturer.
So, what's the scoop on GEX? Good? bad? Indifferent?
Spoke
Spoke   Spoke's 71 2.056L 914 Progress Thread   Dec 28 2007, 10:59 PM
KaptKaos   Whoa! What did I miss??? When did that happ...   Dec 28 2007, 11:11 PM
Spoke   One of the first threads I started on the 914club/...   Dec 28 2007, 11:16 PM
neo914-6   One of the first threads I started on the 914club...   Aug 9 2008, 03:25 PM
Spoke   Threads about the rear ender and repairs: Short T...   Dec 28 2007, 11:23 PM
Spoke   Here's some pics of the donor engine with tin ...   Dec 28 2007, 11:40 PM
Spoke   Besides cleaning up the engine and tin, I'll c...   Dec 28 2007, 11:57 PM
Twystd1   Is that a GEX tag on this engine...???????????? ...   Dec 29 2007, 12:09 AM
Spoke   Is that a GEX tag on this engine...??????????? Y...   Dec 29 2007, 03:33 AM
Spoke   I've decided to put the original D-Jet FI from...   Jul 15 2008, 12:43 AM
Spoke   With the MPS connected to the brain and with the e...   Jul 15 2008, 12:47 AM
Spoke   Finally got around to sandblasting the engine tin ...   Jul 15 2008, 01:03 AM
Spoke   Putting the tin back on the engine. The CHT sensor...   Aug 6 2008, 01:14 PM
Spoke   Question about #2 "Seal". This is the 1/...   Aug 6 2008, 04:09 PM
fitsbain   Where are the pictures of that sheet metal I sent ...   Aug 7 2008, 09:49 AM
Spoke   Where are the pictures of that sheet metal I sent...   Aug 7 2008, 10:36 AM
watsonrx13   Man, I hope you used that 2-part expoy.... :woohoo...   Aug 7 2008, 12:13 PM
Spoke   Got the plenum cleaned up and painted. Checked sup...   Aug 8 2008, 11:45 AM
Spoke   Plenum is bolted on. Tin is mostly in place. Ready...   Aug 9 2008, 05:28 AM
Spoke   Decided to make gaskets to put between the intake ...   Aug 9 2008, 06:05 AM
Spoke   Started to reassemble the distributor and noticed ...   Aug 11 2008, 10:16 PM
Spoke   When I installed the distributor, I noticed that w...   Aug 11 2008, 10:25 PM
Spoke   Got all the FI stuff on the engine that is needed ...   Aug 11 2008, 10:32 PM
Spoke   Woo Hoo! :Qarl: it is alive. Running on FI ...   Sep 6 2008, 11:22 AM
Spoke   Put the engine on a furniture dolly today. Now I c...   Sep 8 2008, 11:20 PM
Spoke   Started removing stuff from the engine. These IDF4...   Sep 8 2008, 11:22 PM
Spoke   My first engine drop. Piece of cake. Put my floor ...   Sep 15 2008, 03:23 PM
Spoke   The while-I'm-in-there syndrom will include SS...   Sep 15 2008, 03:26 PM
Spoke   Started work on reinforcing the longs. The repair ...   Apr 7 2009, 06:10 PM
Spoke   Cut the lower part of the fender off. The door jam...   Apr 7 2009, 06:34 PM
barada   Cut the lower part of the fender off. The door ja...   Apr 7 2009, 06:46 PM
Spoke   There is basically nothing left of the lower part ...   Jun 1 2009, 09:45 PM
Spoke   Preparing to weld the steel plate to the existing ...   Jun 1 2009, 09:57 PM
Spoke   I would make more progress on the 914 if I didn...   Jun 1 2009, 11:01 PM
Spoke   The replacement plate is welded in. Like the steel...   Jun 1 2009, 11:06 PM
Spoke   Here's a fix I did a while back when I was ref...   Jun 4 2009, 09:36 PM
Spoke   Removed all the tar on the passenger side floor. I...   Jun 7 2009, 08:59 AM
Spoke   The inside long has been patched from front to bac...   Jun 7 2009, 09:03 AM
charliew   Where the door gaps still good before you started?...   Jun 7 2009, 12:35 PM
Spoke   Got the gas tank and center fuel lines out today. ...   Jul 18 2009, 08:43 AM
Spoke   This pic was supposed to show the rust around the ...   Jul 18 2009, 08:47 AM
Spoke   A while back I repainted the trunk and relocated t...   Jul 18 2009, 08:53 AM
Spoke   I ground down the flange for the tailshift boot. I...   Jul 18 2009, 10:01 AM
Spoke   Ground off the previously added web and original w...   Jul 18 2009, 10:06 AM
Spoke   This patch will join the bottom long plate to the ...   Jul 20 2009, 10:38 PM
Spoke   The patch is now welded in place. Just the front t...   Jul 20 2009, 10:44 PM
Spoke   Also got the sideshift cover flange welded on. ...   Jul 20 2009, 10:48 PM
Spoke   Got the back of the passenger floor patch done ton...   Jul 22 2009, 11:20 PM
FourBlades   Those are nice looking repairs. :Qarl: Should ...   Jul 23 2009, 09:48 AM
Spoke   Cleaned up the firewall around the heater tube. I...   Jul 25 2009, 10:32 AM
Spoke   The 2nd piece around the heater tube is now in. I ...   Jul 25 2009, 10:39 AM
Spoke   Patched the holes in the floor, inner firewall, an...   Jul 25 2009, 07:46 PM
Spoke   Last of the patches for the passenger side seat ar...   Jul 26 2009, 04:26 PM
Spoke   I'm ready to install new jack posts but it see...   Sep 11 2009, 07:15 PM
FourBlades   Your car is really coming along. You jack tube st...   Sep 11 2009, 09:09 PM
Spoke   Your car is really coming along. You jack tube s...   Sep 11 2009, 09:20 PM
Spoke   Here's one of the other things I've been t...   Sep 11 2009, 09:15 PM
Spoke   Mock up of jack tube using Rich Towle's locati...   Sep 12 2009, 01:16 AM
Spoke   Jack plate looks good. Length of jack tube is ab...   Sep 12 2009, 01:20 AM
Spoke   I used the little piece cut out from the long to s...   Sep 12 2009, 05:34 AM
Spoke   One last hole in the longitudinal patched. Engine...   Sep 13 2009, 02:13 PM
Spoke   I have a metal bar sitting around so I thought I w...   Sep 13 2009, 02:33 PM
Spoke   Put a couple more steel bar supports in the long. ...   Sep 13 2009, 09:51 PM
Spoke   Jack support plate ready for welding. Presto...   Sep 14 2009, 05:57 AM
Spoke   After some deliberation, I decided to investigate ...   Sep 21 2009, 08:54 PM
Spoke   Cleaned back to good metal and patched. That looks...   Sep 22 2009, 05:44 AM
Spoke   The long is ready for the support plate. The gray ...   Sep 24 2009, 10:08 PM
Spoke   The support plate is welded in. Gray weld-through ...   Sep 24 2009, 10:12 PM
Spoke   What to do if your nuts are too small: weld 2 toge...   Sep 24 2009, 10:51 PM
Spoke   The suspension pick-up will be seam welded, then t...   Nov 16 2009, 04:05 AM
Spoke   The suspension pick-up is welded on including the ...   Nov 16 2009, 04:17 AM
Spoke   Finally time to patch up the hole looking into the...   Nov 16 2009, 04:23 AM
Spoke   Support plates between inner and outer suspension ...   Nov 16 2009, 05:03 AM
veltror   Excellent thread, I thought mine was the only one ...   Nov 16 2009, 09:17 AM
FourBlades   That is some great looking repair work! :tro...   Nov 16 2009, 09:19 AM
raw1298   Awesome job :welder: :headbanger: . Gets me pumpe...   Nov 16 2009, 12:14 PM
Spoke   The original hell hole repair put that little patc...   Nov 21 2009, 08:43 AM
Spoke   And Presto! The 2 plates may add a little bit ...   Nov 21 2009, 08:48 AM
my928s4   Nice work, that looks like it will last a looooong...   Nov 21 2009, 08:57 AM
Spoke   The passenger side engine shelf is a replacement. ...   Nov 21 2009, 10:32 PM
Spoke   Prepping for paint. I either have a red car or a y...   Nov 23 2009, 05:41 AM
Spoke   Primer going on now. Just painting the inner fende...   Nov 23 2009, 07:39 PM
Spoke   Had paint on then decided to fit the swing arm mou...   Nov 25 2009, 11:38 PM
Spoke   Got the paint finished tonight. Feels like I'm...   Nov 25 2009, 11:44 PM
Spoke   Putting the rear suspension back on. Had to spruce...   Nov 30 2009, 12:05 AM
Spoke   Caliper on. I had plenty of clearance betwee...   Nov 30 2009, 12:10 AM
Spoke   I finally got the car turned around in the garage ...   Dec 2 2009, 08:19 PM
Spoke   This side was also repaired like the passenger sid...   Dec 2 2009, 08:37 PM
watsonrx13   The grommets go on the missing triangle underneath...   Dec 3 2009, 07:07 PM
Spoke   Thanks for the photo Rob. I think I'm missing...   Dec 4 2009, 01:49 AM
Spoke   What! Another rust through hole on the drivers...   Dec 5 2009, 11:06 AM
Spoke   Post Whore. The World timed out again and doubled...   Dec 5 2009, 11:15 AM
Spoke   Here's the Ace Hardware seat pivot repair. Not...   Dec 5 2009, 04:18 PM
my928s4   Here's the Ace Hardware seat pivot repair. No...   Dec 5 2009, 10:00 PM
Spoke   Here's the middle support. I guess the clutch ...   Dec 5 2009, 04:22 PM
sendjonathanmail   Hey man, did you use an airbrush when you painted ...   Dec 5 2009, 09:19 PM
Spoke   Hey man, did you use an airbrush when you painted...   Dec 6 2009, 05:47 AM
Spoke   The clutch tube was repaired before as there is a ...   Dec 6 2009, 08:51 AM
Spoke   So what shape should the clutch tube have? This on...   Dec 6 2009, 10:13 AM
Spoke   The plate for the firewall is completed and ready ...   Dec 6 2009, 07:36 PM
4 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 3rd April 2025 - 01:21 AM
