VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
So, at the Sterling meet I did a leakdown test on my motor, and found a problem with Cylinder 1. 45% leakdown, but 120 lbs of compression. Was tempted just to let sleeping dogs lie, but pulled the head off.
What was going on was clear as soon as we did that, the head was not totaly sealed to the cylinder, off by a very small amount. Instead of having the head recut, I decided to try and lap the two of them together. So, last night I hand lapped them, using ground graphite to check for even contact. I got good contact after the third round of hand lapping (lap, clean, check). Now I need to get the jug back on the block. I have a ring compressor on the piston, but I can't ficgure out how to get the head back on. Do I have to take the piston head off the rod? If so, how do I get it off. It looks like that tis a spring keeper that needs to be removed. Is there anyhting on the rod the needs to be loosened before I can pull the pin out to remove the piston head? Obviously, if there is a trick to getting the jug back on without pulling off the piston head, I'd like to do that. Zach |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
I got him fixed up. I gave him 2 cylinders (so if he drops one he is still ok (IMG:style_emoticons/default/poke.gif) ). Now he just has to have them punched out and then he can fool with this some more.
Lo-Fi Version | Time is now: 25th June 2024 - 10:22 PM |
